DarkLight
- Apr 21, 2016
- 13
- 606
- 563
- LA
- Civic-2016 LX 6MT
True, but the gauge doesn't appear to reflect exactly what the logs are reading at. All the logs show sustained boost in the 12-14 psi range at WOT. I'd be running an analog boost gauge if I had a 1.5.its most likely a spike
It should definitely be making more power with the lower knock values, so that kind of stumps me since yours is pretty much optimal. Additionally, ignition appears very conservative 4-8* BTDC max sustained. So definitely not knock.
Also, your injection duty cycle only maxed out at 30%! I am very surprised by that. That means you've got room for a much bigger turbo on this motor.
ETA: After reviewing all of your logs, it seems the ECU is partially closing the throttle plate as the CVT changes it's ratios and that is causing a dip in boost, which takes some time for the turbo to regain. That is probably to prevent a torque spike from causing damage.
