NathanDrake
Just curious if I should regularly be using either of these.
I'm guessing the electronic brake should be used every time I park, even on a flat surface? This is the first vehicle I've owned with an electronic parking brake, and I'm concerned it will go bad and need to be replaced if used frequently.
At first I was a bit startled when I kept hearing the EPB 'noise', but I assume this is completely normal... doesn't the parking brake help the transmission a bit when parked?
Brake hold, I have no idea. It's not something I absolutely need to use, but would be nice occasionally at longer stop lights. I'm just worried that it's one more thing that could go bad.
