eoevangelion
- Richard
- Jul 31, 2018
- 2
- 22
- 5
- Apple Valley CA
- 2017 Civic Sport Touring
Hello! I recently installed the Sirimoto flexfuel kit on my 2017 Civic hatchback touring. Straight forward just unhook the fuel lines and place in the new new ones. Tuned with hondata and the car fired up no problem. I then went to install the gauge. I followed the instructions to the best of my knowledge, disconnecting the negative terminal first, triple checking everything and reading the instructuonsi10 times over making sure the correct fuse was removed and replaced. Making sure the wire was grounded and making sure the gray #54 wire was spliced with the yellow wire on the kit. I went to start up the car and every single light was on. I mean every single one, Cel, hill start assist every vsa light, etc. The car still runs although it's in limp mode. Ran it to the dealership the other day and had a new ecu overnighted as they said it was fried. They replaced it and the problem still persists. Now they say I need a new wire harness which brings the total to 2k$. Is there anything else I can check or try before spending that money On something that may not even fix the problem? I reflashed the ecu multiple times, disconnected the battery for about 20-30 minutes. The code the flashpro shows is p2122 which is low voltage in the gas pedal. Anything I can try before I go to the dealership again? Any suggestion is appreciated !!
