easiest way to disconnect battery for ECU reset?
farqt
NE
18 si
is there a quick connect anywhere over than on the battery terminals to safely depower the ECU for a few minutes? i am seeing some weird stuff on extended CAN and i want to reset the ECU and let it recal long term trims etc. to see if the behavior goes away. it's quite annoying to have to disconnect at the battery terminal to do this. has anyone found eg a fuse that can be pulled more easily for ECU reset?
calonzo
New Haven, CT
2016 Honda Civic Touring
You can try this fuse in the engine compartment.
12 FI ECU 10 A
