Does your SI pull to the right or left?
PWP19SI
Pennsylvania
08 Civic LX 16 HRV EX
When accelerating does your SI pull to the right or left? I know we have a limited slip diff, but is it still possible that the SI will pull to the right under acceleration?
A2typeR
Ann Arbor
2019 Honda Civic Si sedan (TSP stage 1) 2016 Mazda Miata Club (Brembo BBS pack)
Check your alignment should go straight unless you are pulling the wheel left or right or on a uneven or sloped surface etc.
Gotch
Rob
2022 Si
Straight here as well under heavy acceleration.
PWP19SI
PWP19SI
Pennsylvania
Had a set of new tires put on and now when I accelerate the car pulls to the right. Driving me up a wall.
jakabony
Jake
Pittsburgh PA
www.facebook.com
2017 Honda Civic Si, 2019 Honda CR-V EX-L, 2017 Subaru Forester
Check your tire pressure. Maybe they aren’t inflated evenly.
silverblip
Dan
Newport News VA
2020 Toyota TRD Off-Road MT
I saw your other thread about the same subject. Did they align the car after the tires were put on?
Triple_peaz
Brother Taresa
Brandon
Louisiana
2019 Honda civic si sedan, 2016 Honda pilot
I was pretty sure that all vehicles pull slightly to the right for safety reasons. Like if you fall asleep at the wheel instead of drifting to the left into oncoming traffic you go right. Let me know if I'm wrong
PWP19SI
PWP19SI
Pennsylvania
No, I don’t think so. The car doesn’t appear to be out if alignment when coasting or at cruising speeds, but when I accelerate at 50% plus throttle it starts to pull right enough that noticeable.
I did this too and low and behold the rear driver side tire was at 25psi. Adjusted that and it corrected the steering resistance, but still pulls right at 50% plus throttle it still starts to pull right.
Very frustrating considering I baby the car, aim for good mpgs and don’t drive it everyday.
PWP19SI
PWP19SI
Pennsylvania
I’m starting to think it’s just the torque steer along with the all season tires that is causing the car to pull right.
I’ve been testing this all different ways. Cruising the car goes straight. When I throttle down it pulls right. This happens while barely touching the wheel allowing the car to stay straight or pull.
Thanks for anyone that’s chimed in. This has been driving me nuts all day.
Justin
Justin
New Jersey
2017 Civic SI
Bruh i got my car aligned TWICE and it still pulls to the right. I can easily go 100mph and hold my wheel straight, but i believe that the steering wheel is not centered which is causing it to go right.... I bought my car back 3 times for the 2nd alignment to no resolution. Pretty annoyed lol
Kable's2019Si
Patrick
2019 Civic Si, 1992 C1500 383
Your car can drive straight at cruising speeds and still be out of alignment. If the toe is straight but your caster/camber is out it will drive straight, when you hammer down it changes the geometry of the suspension and caster and camber can play more of a factor. Or if the toe is out evenly on both sides you won't feel it until under a load. Alignments aren't expensive compared to the wear it's going to do on tires and other parts.
Kable's2019Si
Patrick
Then take it somewhere else. They are obviously not doing it right. You need a good front end tech doing it.
Rc1989
2019 civic si
Only thing different is tires and problem happened after they were installed. So I would start there
