Does weather does affect performance?
  1. amirza786
    amirza786 Senior Member
    Oct 4, 2018
    1,864
    1,689
    Occupation:
    Director of IT Operations
    San Jose, California
    A Mirza
    2006 Camry SE V6, 2013 Toyota Sienna LE, 2018 Honda Civic Si
    #1 amirza786, Feb 11, 2019
    I've owned my 2018 Civic Si Since June (8 months), and I notice that temperature does affect performance. I have found that if the temperature is 50 F and above, my car performs much better, everything from acceleration to better gas mileage. For example, yesterday was a nice 55 degrees F, and everything was so much smoother, from shifting to basic acceleration. Also I was averaging 31 mpg doing some spirited driving. This morning the temp was 38F (cold for the Bay Area), and even after everything was warmed up, I felt as though I had to push down harder on the pedal. Accelerating seems a bit more restrained, shifting not as smooth, and average gas mileage this morning dropped to 26 mpg. Also I feel boost takes a bit longer and is much less.
    What I feel is that this car drives much better between 50 degrees and 90 degrees F. I don't know if it's the ECU maybe tuning things down or possibly the transmission doesn't work as well in the cold. I don't have this issue at all with my two Toyotas, they drive the same cold or hot weather. Does anyone else feel the same, that your Si drives better in warmer weather? I would like to know if I'm the only one who notices this.....
    EDIT
    I want to make it clear, it does not drive bad in colder temps, performance just seems a bit down compared to driving in warmer temps
  2. Davsonamission
    Davsonamission Senior Member
    Feb 4, 2019
    226
    215
    35235
    David
    17 Civic Si Coupe
    Wait what? Really? It is a turbo car the colder the better or am I getting that completely wrong? My car is noticeably faster in colder weather... I think :D
    saz468 thanked this.
  3. OP
    amirza786
    Oct 4, 2018
    1,864
    1,689
    Occupation:
    A Mirza
    That's what I hear, colder air is better for turbos
  4. gtman
    gtman Senior Member
    Oct 27, 2015
    5,128
    5,195
    Occupation:
    CivicX addict
    U S of A
    2017 Cosmic Blue Civic EX-L
    Colder air is denser and generally better for performance. In very warm weather, where IAT's get too high, power will suffer. Moderately cool temps in the 45-65 range seem to be the sweet spot.
    In really cold weather, it takes longer for the car to warm up and MPG's will suffer.
    amirza786 thanked this.
  5. b4gel
    b4gel Senior Member
    Jul 5, 2018
    55
    64
    DC
    '18 Si sedan
    Once the engine is up to temp, followed by the transmission not long afterward...there should be no difference. Your car's thermostat is set somewhere around 200 degrees. Once it's up to temperature, it's unphased by the ambient temp unless it's truly extreme conditions.
    Additionally, colder air is denser. Once your car is up to temp it should be performing better, not worse, in the cold thanks to the lower intake temperatures.
    Fuel economy does take a hit in the winter though for a lot of people...longer warm up periods, under-inflated tires, winter grade gasoline, denser air causing higher drag, etc.
    If you truly think the car is performing worse in the winter, you may want to take it to the dealership because that does not sound normal.
  6. OP
    amirza786
    Oct 4, 2018
    1,864
    1,689
    Occupation:
    A Mirza
    As I mentioned, it's not performing poorly, it just seems like I have to go a bit harder on the pedal when it's colder (weatherwise). I'm thinking it's more the transmission taking longer to warm up....
  7. NoelPR
    NoelPR Senior Member
    Nov 16, 2016
    391
    329
    Occupation:
    BI Specialist, Jr Data Scientist
    15' Lancer Ralliart
    Colder Air is more dense, oxygen rich.
    Barometric Pressure
    Humidity
    The one with the biggest effect is temperature. The colder the more power it makes.
    Ideal conditions for maximum power.
    High Barometric Pressure
    Low Humidity
    Cold Temps
    Sea Level Altitude
    Also there are lots of apps that gives you the density altitude of your area. It tells you a relative altitude of your surroundings.
    Right now in my location the density altitude is 1600ft but my real altitude is 120ft (central florida).
    My car is performing like is on a hill @1600ft and you know that the higher the altitude the worse is the performance of an engine specially on naturally aspirated ones.
    When is really cold around low 40s I can see a density altitude of negative 2000ft and the car is pretty happy out there.
    Also Dynos when they correct the reading they take into account the weather of the day of the run.
    300whp on a very hot day aren't the same 300whp on a very cold day.
    Captaindicki and amirza786 thanked this.
  8. ablueSI
    ablueSI Senior Member
    Jan 2, 2019
    198
    153
    SF Bay Area
    '18 Civic SI Sedan
    I am convinced that weather affects the performance on our Si's but I will leave the science to others who know better than I.
    From the seat-of-the-pants, I do sometimes notice that half the time I'll floor it and think "hmmm that was alright" versus other times where I'll think "holy that was quicker than I expected."
    Not sure if others have had the same experience but I think it is totally a turbo-eco four thing to cut timing now and then.
    BoostedSiCoupe and amirza786 thanked this.
  9. SiGeddy
    SiGeddy Senior Member
    Jul 1, 2018
    97
    38
    Bakersfield
    Geddy
    2017 civic si
    That happens to me. I'll mash the pedal sometimes and go no where. And other times I'll do the same exact thing and get sucked back in my seat.
    amirza786 and ablueSI thanked this.
  10. gtman
    gtman Senior Member
    Oct 27, 2015
    5,128
    5,195
    Occupation:
    CivicX addict
    U S of A
    No question. In my experience, the turbo seems to prefer milder, low humidity weather like what you'd see in Spring or Fall. Hot, humid summer temps sometimes has the car falling flat on it's face.
  11. OP
    amirza786
    Oct 4, 2018
    1,864
    1,689
    Occupation:
    A Mirza
    See, there you go, that's what I'm talking about! This morning when it was about 38 to 40 degrees F, performance seemed a bit off, I had to go harder on the pedal. I just got back from picking up my son from school, it's about 58 degrees F and I barely had to step on the pedal, performance was much better, shifting as well. I'm not the only one who notices this!
  12. OP
    amirza786
    Oct 4, 2018
    1,864
    1,689
    Occupation:
    A Mirza
    I actually had no issues in the summer when temps reached over 90 degrees F. The only time I ever felt heat soak was after an 8 hour drive in over 115 degrees F going from Northern California to Los Angeles, I was averaging around 80mph most of the trip. I felt the heat soak as soon as I hit LA traffic, it was in the upper 90's in LA, humidity was relatively high
  13. ablueSI
    Jan 2, 2019
    198
    153
    SF Bay Area
    '18 Civic SI Sedan
    I won't lie, after owning 3 N/A cars in a row (and sadly one hybrid) the unpredictability of the engine considering both temperature and turbo lag is legitamitely exciting to me.
  14. OP
    amirza786
    Oct 4, 2018
    1,864
    1,689
    Occupation:
    A Mirza
    If you really want to know what makes this car great, drive it between Northern Cal and Southern Cal. When you hit the steep inclines on hwy 152 and the Grapevine area, you will be amazed at how this tiny little engine handles those steep hills...in 6th gear! I have only had to use 4th and 5th gears to pass slower traffic
    Captaindicki and ablueSI thanked this.
  15. ablueSI
    Jan 2, 2019
    198
    153
    SF Bay Area
    '18 Civic SI Sedan
    Oh I have, twice now :) I was indeed amazed! The car felt incredible.
    Captaindicki thanked this.
