Does my car battery look normal?
Apollo!
Howell, MI
Honda Civic EX 2016
Or is it normal wear and tear?
2016 Civic EX, had it since July 2016 and 42500 miles on it.
Honda Civic 10th gen Does my car battery look normal? jbVFQLK
shoegazer
Raleigh NC
2018 Civic LX Coupe 2.0 (CVT)
I agree that it is just normal corrosion. However... maybe take the opportunity to replace the battery since the OEM ones were cheap. Yours is 3.5 years old now. It is in the twilight of its life span.
Also... be careful loosening the battery connectors. Some folks unscrew them too far, the locking nut comes off of the bolt, and it is lost forever into the abyss of the engine bay.
latole
Vaudreuil,Quebec ,Canada
tackthecat is right
Lots of Baking soda in a bit a water, like 1 teaspon od baking soda on 1/2 cup of water
Look under the red plastic housing too.
Let them dry before putting grease.
All battery and engine compartment need good cleaning. Did your car see a good mechanic over yesr ?
Apollo!
Howell, MI
Honda Civic EX 2016
Got it cleaned up.
What brands do you recommend if I want to get the battery replaced?
shoegazer
Raleigh NC
I bought the Duralast Gold one from Autozone. It was the top of the line other than the AGM model (which I'm told to avoid for now).
See if you can talk the sales person into pulling a fresh one off of the back of the dispenser. The ones front and center are usually the oldest.
Martin Riggs
NJ
2017 Honda Civic Hatchback EX
maybe in my area Honda always comes out with the better deal with their 100 month warranty.
OP if you go to Honda and show that corrosion you will prob get a prorated deal on battery or if best a new one. Let us know how you make out.
latole
Battery terminal ; it is not corrosion, it is a normal phenomenal
No need to buy new battery
Apollo!
Howell, MI
Honda Civic EX 2016
Here's the after picture.
I'm going to wait until there are signs of slow start or any issues related to the battery then I will immediately buy a new replacement. But it is fine for now...
Honda Civic 10th gen Does my car battery look normal? KJUHY8U
