Does anyone have the part # for the Si HDMI tip?
MutatedMango
Philadelphia
'19 Civic Si FC3
Looking to get a muffler delete but want to keep the HDMI tip on bc I enjoy it. Does anyone have the part number for just the tip?
amirza786
A
Northern California
REBELXSi
Señor Member
I have a muffler delete and I still have the HDMI tip. You don't have to change the tip.
Here's the part you need:
Honda Civic 10th gen Does anyone have the part # for the Si HDMI tip? IMG_20200120_200030
COOL COUPE
South Carolina
2019 Civic SI coupe (red) Skunk 2 shift knob BOV Spacer Plate (red) K&N Panel Filter Dual Muffler Delete
I have the muffler delete! Zero drone at high way speeds ... Which is STUNNING! There is a harmonic disturbance at only a certain rpm ... Muffler shop welded in two stainless steel pipes ... I moved to SC but paid New York price at $220 ... Lost 35 pounds of weight ... Very nice mod ... Don't let them scare you off ...
amirza786
A
Northern California
Boo!
REBELXSi
Señor Member
It's pretty simple... as pictured. You literally just remove the mufflers and keep the old piping. Just need to link the pipes.
Honda Civic 10th gen Does anyone have the part # for the Si HDMI tip? 2019-01-21 11.45.05-1
COOL COUPE
South Carolina
Silly question ... My apologies ... Is this single exit exhaust? Or true dual? I noticed that my exhaust guy cut the exit pipe on the stainless steel extension at different lengths as if this was an attempted to "phase" the pipe. When I look into the HDMI I see it clearly. My assumption though is that the sounds of both chambers are the same and this is just a fitament issue.
MutatedMango
MutatedMango
Philadelphia
'19 Civic Si FC3
Interesting, people above were saying to worry about droning. I guess not. Thanks!
MutatedMango
MutatedMango
Philadelphia
'19 Civic Si FC3
Good question that I unfortunately can't answer :(
The guys above are smart af though and probably know the answer to that
REBELXSi
Señor Member
There IS droning. It's only off throttle though and at certain RPM. When you're cruising, you can barely tell there's anything different about the exhaust.
REBELXSi
Señor Member
I'm not sure I understand the question because the answer seems obvious to me. The HDMI tip does have two exhaust exits mashed side by side. Take a peak inside yours. That being said, this exhaust system is most definitely not a dual exhaust system as there is only a single exit from the engine head and then the turbo and the majority of the exhaust system consists of a single pipe.
amirza786
A
Northern California
As @REBELXSi stated, a single exhaust pipe from the CAT splits at a T-junction and connects to the mufflers. See the pic I posted of the exhaust (Post #2)
Oddwayne
Nj
19’ Si coupe & 99 ej6
What rpm is your drone at
