Do tires really have to be rotated?
  1. daniellee789
    daniellee789 Senior Member
    May 15, 2019
    207
    39
    Georgia
    Daniel
    2019 Honda Civic Hatchback EX
    So my dad always gets mad at me when I tell him I need my tires rotated. In his opinion, he thinks it's pointless haha. I guess he just doesn't like changing all the tires at once? He prefers just changing the front tires when they're worn, since the rear tires don't get worn as much. Should I get my tires rotated when I get my oil change?
  2. 2112
    2112 Senior Member
    Jan 31, 2017
    273
    288
    Cleveland, Ohio
    2017 Honda Civic Type R #00969 BLK, 2015 Nissan 370Z Roadster (BLK), 2019 Civic Si Modern Steel Metalic
    Sorry, but your Dad is wrong. Rotate your tires per the preventive maintenance schedule. Alternatively, spend more money and replace your tires more often because of uneven wear.
  3. Ricardowelch
    Ricardowelch Member
    Sep 18, 2019
    1511 Willow Greene Drive
    Ricardo
    2016 Honda Civic
    Most vehicle manufactures recommend the tires should be rotated on the same schedule as oil changes. How long we rotate, it depends on your owner's manual but at least once a year.
    daniellee789, Jay19Si and saz468 thanked this.
  4. OP
    daniellee789
    May 15, 2019
    207
    39
    Georgia
    Daniel
    Don't be sorry haha it's just hard telling my dad he's wrong I'll just go ahead and get my tires rotated with the oil change! I think my dad still has the same rear tires on my old car from when I was driving it lol
  5. Stigglesworth
    Stigglesworth Member
    Sep 29, 2019
    New Jersey
    2020 Civic Hatch
    The reason why you rotate tires is so that the wear patterns suffered by the front tires don't wear them out much more quickly than the rear tires (All you are doing is taking the wheels from the front and putting them on the back, after all). Without rotating tires, the front tires will wear out much faster than if they spent half of their lives in the back.* It will almost assuredly cost more in the long run to not rotate (assuming rotating is either free or done at home).
    I have been swapping between winter and summer wheels for the last few years (every 6 months or so), so I just rotate the tires during the swap. I label the wheels during the changeover(duct tape and Shapie on the inside surface), then put them in the appropriate rotated location on the next swap. It's worked fairly well for the two sets of tires. If I didn't label them, I would have no way of telling which end they came from by the tread pattern alone.
    *This depends greatly on the type of car, and how good your alignment is. Also some manufacturers use different wheel sizes for front and rear. In those cases, it's not an option to rotate the wheels.
    daniellee789 thanked this.
  6. markc72
    markc72 Member
    Apr 20, 2018
    47
    Chicago
    Mark
    2018 Honda Civic Hatchback EX-L w/NAVI
    Your dad is way wrong. Not sure where he would get that idea.
  7. mis3
    mis3 Senior Member
    Aug 22, 2017
    1,435
    276
    Ontario
    PT
    Mercedes, 2018 SI Coupe
    Yes, you should rotate the tires to even the wear.
    With my previous car (MB), the tires were staggered. Since I could not rotate the tires, I Had to buy tires more often.
    Another problem was I used Pirelli and over the years, they discontinued the tires and I ended up with different tires in front and back (OK but not ideal).
  8. latole
    latole Civic Lx 2018 Manual , Civic LX 2016 Manual
    Apr 13, 2017
    1,861
    403
    Vaudreuil,Quebec ,Canada
    Yes ,rotate tires.
  9. jacobegg
    jacobegg Senior Member
    Dec 20, 2018
    205
    70
    Oklahoma
    Jacob
    2016 Honda Civic Touring
    Don’t your tires rotate when your drive the car???:lol::lol:
    (Heard someone say that at work one time... didn’t know how to respond lol)
  10. justasimpleman
    justasimpleman Senior Member
    Apr 7, 2019
    98
    56
    lost
    2019 civic sport mt
    time for a new dad...
  11. coo1rim
    coo1rim Senior Member
    Feb 14, 2016
    1,326
    382
    Occupation:
    driver
    toronto
    1998 civic, 2006 yaris, 2008 rav4, 2012 carmy, 2017 Civic LX
    If you do crazy millage (e.g real drivers) and you have good tires that don't get noisy when they become worn, it's better to burn them out and replace with 2 fresh tires which will go in the back. That way, you almost always have fresh rubber on your car. Fresh rubber is significantly better then ones that are 3+ years old. If you don't do much driving, then sad for you, since you'll have to deal with those old hockey pucks for the life of the car and babe them until they fail you when you need them.
    daniellee789 and JayDiem thanked this.
  12. thebutcher
    thebutcher NSFW
    Dec 23, 2018
    214
    133
    The Cosmos
    The Randy
    1974 Chevy C10 custom deluxe, 2014 Harley Davidson Ultra Limited, 2019 Honda Civic Si coupe
    All car tires wear whether they’re rotated or not. Everything said above is good advice, BUT:
    The main reason you want to keep your tires rotated is for the mileage warranty that comes with your tire. If your tire wears out prematurely or something in the tire breaks and is under the stated mileage for that tire, you can get in touch with the manufacturer to have it replaced.
    BUT the first thing they will ask you is “Did you rotate your tires.” If you tell them “Yes” and I have my receipts. The next question will be “How often did you rotate your tires.” That’s why it’s important to read your manual and find out what is recommended. Or if your replacing an old set, ask the dealer what is recommended for the tires your buying. All these things can help you if your ever in this position and need to prove you did what you were suppose to do to provide the maximum time life for your tires.
  13. Daniel644
    Daniel644 Senior Member
    Sep 1, 2019
    199
    101
    Ellijay, GA
    Daniel
    2016 Civic EX-T Sedan, 2003 Trailblazer LS, 1999 Pontiac Firebird
    in a perfect world you want all your tires to wear out at the same time that way you don't have to worry about finding just 2 tires that are the same model as your other 2, you also typically get better deals because you are eligible for rebates when you buy sets of 4 so in the long run you save more money, the issue with not rotating is say you leave the rear tires where they are and always just replace the fronts as they wear out, the tires on the rear will "age out" (get past the safe age range of 6 years, note some manufactures say up to 10 years) before they wear out and you could end up having a blowout or a tread separation or a shift in the traction of the rubber compound.
    So while technically not "required" it is most definitely best practice and should be done, if he is to cheap to pay someone to do it he can do it himself, these 90 degree days are finally gone and we got some cool mid 70's days so now is a great time to knock out basic maintenance tasks without sweating to death like we would be doing last weekend.
    probably the same logic process of the "Anti-Vaxxers", he probably read some internet forum claiming tire rotations is just another way the tire shops milk you for more money and it has nothing to do with SAFETY.
    brienp thanked this.
  14. AndyAndromeda-AUS
    AndyAndromeda-AUS AndyAndromeda
    Oct 18, 2017
    473
    184
    BNE - Australia
    Andy
    Honda Civic 10th Gen - Vti-LX (Australia)
    Time to rotate your dad.
    AlphaMoose67 thanked this.
  15. gtman
    gtman Senior Member
    Oct 27, 2015
    5,829
    6,197
    Occupation:
    CivicX addict
    U S of A
    2017 Cosmic Blue Civic EX-L
    #15 gtman, Oct 6, 2019
    Honestly, you don't have to rotate your tires.
    But, if you don't, your front tires will look like this much more quickly...
    So, in conclusion:
    1. Rotate your tires every 7500 miles or so.
    2. Rotate your dad in the direction of this thread. :cool:
    360glitch, daniellee789 and brienp thanked this.
