DIY - Wireless charger install
  1. Donuyen18
    Donuyen18 Senior Member
    May 22, 2016
    689
    518
    Garden grove
    Honda s2000
    This is my walk through for installing the Honda Oem wireless charger on a 2016 sedan CVT.
    Other body styles and trims might be different but you can probably still use most of this guide. That being said, check the Manual before attempting this install because different from levels and existing modifications such as the illumination kit will.affect the wiring part of the install. On a scale of 1 to 10 for difficulty, I would only give this about a 2 or 3. I just used the oem instructions and took it step by step. It's a fairly easy install. However, it is a hassle to remove all the panels to get to the install. It feels like Honda is making things more difficult for diyers hoping that we will have the dealership install it for us. This install requires no electrical work unless you count disconnecting and connecting electrical components but there is no need for splicing or wire tapping or crimping.
    Tools needed:
    10mm socket
    Phillips screw driver
    Pry tools or flat head screw driver
    Car key
    Painters tape
    Remove the negative terminal from the battery
    Pry the lower dash panel and remove. Reach under with your hand and pull forward. Don't yank too hard because there are some connections that will still be attached.
    There are 3 connections to remove. The 3rd connector is on the right side. I moved the panel to the back seat.
    Remove the driver side armrest. You will need to wedge the prytool in between the armrest and the base to separate them. You can use a flat head but just be careful not to scratch anything.
    Place some painters on the infotainment so that you don't scratch it
    Remove the driveside console trim piece. This is the same as the armrest. Use the prytool to separate. The trim is a more difficult to remove then the armrest. Don't use too much force because you don't want anything to break but some force will be needed for these parts.
    Repeat the process for the passenger side
    Remove the climate control. It is held in by clips so use light force to pull it forward. Don't pull too hard as there are connectors attached
    Remove the panel on the rear of the console. It is held in by clips. I had to use some force to remove this part. If you have a higher trim that has the rear vents or rear seat warmers, remember to remove those wires as well.
    Open up the armrest cover and slide back the drink holder and coin tray to give yourself some room.
    On the inside of the console near the front, there's a small runner cover that is shapped like a rectangle. Remove the cover. Grab a car key and insert. This will allow you to move the shifter to neutral. If you have a manual, you only need to remove the shift knob by spinning it.
    Remove the trim surrounding the shifter. Start by removing the 2 screws on the sides. Then pull up with light pressure to remove the trim. Again, be careful as there are connectors attached beneath. Detach the connectors.
    Remove the original tray. It is held in by clips so just yank it upwards to remove. You can toss the tray.
    Pull up on the bezel around the shifter to detach it from the console panel.
    Remove the console panel. It is attached by two screws and one bolt. Put the panel to the side.
    Remove the rubber tray
    Use a prytool or screwdriver and insert it into the small space shown below. This will cause the panel to pop out. Be sure to remove the connectors attached.
    Remove the lower tray. Remove the connector near the top.
    The instructions say to completely remove the side panels on the center consoles. I was able to just pull back the panel near the front.
    They provide urethane tape. Cut the tape in half and apply the correct areas. I was not able to take a photo of this so I'll add the instructions.
    Place the fuse label onto the harness
    Plug the wire harness into the car.
    Attach the wire harness into the small white connector. Attach the additional adapter below that. Please note that this will vary with trims and existing accessories you may have installed. Please refer to the instructions for your particular set up.
    Attach the ground wire to the frame. I used a spot that had multiple grounds already attached
    Run the wire harness to the center console. I used the instructions for this part.
    Reverse the order and install the side panel>lower tray>usb panel cover>rubber mat for lower tray>console panel. Be sure to attach console panel with the two screws and bolt.
    Connect the clip from the wire harness to the home in the diagram.
    Place the wireless charger unit below the screen where the upper tray use to be. Attach the wire to the unit. Secure the unit with two screws.
    Place the new upper tray around the charging unit and press down to pop the clips into place.
    Add the supplied 20 amp fuse
    Reverse the order to complete the install.
    Shifter bezel>shifter trim>shift to park> insert rectangle rubber cover> rear console cover>climate controls>console trim covers>arm rest cover>lower driver panel>hook up negative terminal to battery.
    Start your car to test the charger. The light will not be on. Hold the power button until light turns on. When light is green, it is on stand by mode
    Place your phone on the charging pad to confirm it's working.
    Final thoughts.
    This is a very expensive mod and time consuming. This is my wife's car and she really wanted this feature so had the dealer throw it in when I was buying the car. Again, this is not a very difficult mod but it is time consuming. It has a very clean look to it. It also adds an additional charger to your car for a total of 3 chargers.
    sleepingawake, djlythium, NoKz and 14 others thanked this.
  2. JDM_DOHC_SiR
    JDM_DOHC_SiR Uncle Dave
    Apr 17, 2017
    925
    1,054
    Occupation:
    Government
    Chula Vista/ Eastlake
    2012 Acura TL Califonia Edition / 2018 Civic Si Coupe
    Great write up with lots of detail! Thanks for taking the time to do this for others!:thumbsup:
    ActiveArch and Donuyen18 thanked this.
  3. 2018SportHatch
    Oct 24, 2017
    Vancouver, BC
    Bart
    2018 Civic Sport Hatch
    Great write up, will be one of my future mods.
  4. kotarou
    kotarou Senior Member
    Oct 6, 2017
    78
    Brazil
    Honda FC2 - FFV
    Great Job!
    Do you have all the part numbers required for this mod? I tried to see online and it seems that there are 2 parts involved.
  5. hatch_dawg
    hatch_dawg Senior Member
    May 10, 2017
    105
    Visalia, CA
    Julian
    2017 Civic Hatchback Sport 6MT
    Great job I was thinking about doing this to my hatch
  6. OP
    Donuyen18
    May 22, 2016
    689
    518
    Garden grove
    Honda s2000
    Wireless Charger (08U58-TBA-102)
    Attachment Kit (08U58-TBA-110A)
    kotarou thanked this.
  7. roth91
    roth91 Senior Member
    May 13, 2017
    97
    San Antonio
    2017 Honda Civic
    Will carplay work through the wireless charging on the iphone 8 or X? Apple said it would but I am hearing different.
  8. ShuJam
    ShuJam Senior Member
    Apr 15, 2017
    272
    210
    Toronto, Canada
    James
    2017 Honda Civic Sport Touring Hatchback
    The head unit does not support wireless CarPlay. You still have to plug your iPhone in.
  9. n3o
    n3o Member
    May 1, 2016
    Phillipines
    Civic
    Do the wireless charging supports fast charge?
  10. OP
    Donuyen18
    May 22, 2016
    689
    518
    Garden grove
    Honda s2000
    No,atleast not to my knowledge
    n3o thanked this.
  11. n3o
    n3o Member
    May 1, 2016
    Phillipines
    Civic
    Oh thanks!
  12. sofaking
    sofaking Senior Member
    Sep 4, 2017
    66
    70
    NC
    FK8 #5497// JDM AF Z33
    good stuff!
  13. Pogi R
    Pogi R Member
    Dec 22, 2017
    Seattle
    Jay
    17 PMM Type R #00153
    I wish I saw this before I started my install.. I think i'm around 4 hours now but it's 100+ degrees outside so I am doing it in spurts. I'm currently stuck on trying to find a ground. I see where it shows on the instructions but it seems to be out of reach with so many obstacles I the way. I didn't see a ground that looked like yours. (mine is a Type R) but I figured they should all be the same.
  14. ShuJam
    Apr 15, 2017
    272
    210
    Toronto, Canada
    James
    Glad the wireless charger comes standard from the factory on all Touring/Sport Touring, Si, and Type R models in Canada. This looks like a real PITA to DIY.
  15. LoneStarFlatLanders
    LoneStarFlatLanders Senior Member
    Jun 13, 2018
    73
    74
    DFW - Texas
    2018 Rallye Red Civic Si
    Holy cow that is a lot of work. I think I'll scratch that off my list of things to do! :) A little too intense just for wireless charging. I keep other "crap" in that spot anyways.
