hondo
- Nov 9, 2015
- 20
- 605
- 456
- NJ
- '16 Civic Touring
- Vehicle Showcase
There are a lot of solutions people have tried in order to fix the subwoofer rattle problem in their touring. Some are as simple as padding around the 3rd brake light in the trunk. Others are more extensive and involve removing the rear deck. Materials range from socks to foam to dynamat. I have posted my own fix here:
http://www.civicx.com/threads/touring-subwoofer-rattle-fix-and-dampening.1297/
This did work pretty well for a while, but I have found that the foam can compress over time. This can cause it to shift out of place and otherwise lose effectiveness. So I started researching for a better material and came across something called sorbothane. It's a visco-elastic polymer designed to absorb vibration. I ordered these little domes:
http://www.amazon.com/Isolate-Sorbothane-Hemisphere-Non-Skid-Durometer/dp/B0084EKSNI
I wanted something small so it wouldn't be too visible. I also wanted something about 1/4" thick. That's about the right thickness so that it just squeezes between the brake light and the rear window. For sorbothane to work properly, it needs to be under a slight load so that it bulges on the sides. I chose a durometer level of 30 because it won't have a lot of weight on it.
To apply it, I removed the backing to expose the adhesive and put it on the edge of the putty knife so that just a little bit was on the edge. I then pushed down the rear deck and slid it between the brake light and the rear glass. After releasing pressure on the deck it should be squeezed in there so you can gently remove the putty knife. Here is how it looks.
You can push it in a bit more from the side with the putty knife so it's less visible. I used a total of 4, one near the bottom of each side and one near the top corner of each side.
After testing, I found that it totally eliminated the rattle. Since it's got adhesive on one side and it's tacky it should not move at all. I anticipate that it should last a long time since it's often used for machines and electronics. The only concerns are if sunlight will effect it over time and it may leave some stains. The stains aren't too much concern since it's such a small area and it's pretty hidden.
I've posted video of the results. In the video you can see the audio settings I am using, along with the volume level. The volume is turned all the way up on the phone, which is a click higher than it normally would be. You can see that the bass is loud enough to visible shake the mirror, but you don't hear rattling or smacking at all. I'm very pleased with the results. I will update later about it's longevity. Feel free to ask questions or offer suggestions. Enjoy.
Update: 6 weeks in and the fix is holding up well.
