DIY: Si or CTR Rear Stabilizer Bar on Normal Civic Sedan/Coupe/Hatch
HatchPanda
SouthFL
2017 Civic Hatckback Sport 6MT
I updated this with findings about the aluminum endlinks from the accord in a suspension thread here.
Nice find man. Ive been wanting to do either the Si or TypeR rear sway, but I keep reading different things everytime. What set up do you have/recommend for a sport hatch?
derbo904
derbo904
Keeper of Blinky lights
Bay Area, CA
17 FK7 | 11 E90M3
It really depends on what you are trying to achieve. If you plan to keep the car with stock springs/shock/struts, I would opt for an Si Bar if you want a little more turn-in response. The CTR bar is great but with a stock non-Si/CTR suspension, I feel like it is overworking the rest of the car. I personally think it needs either a front bar upgrade or more spring/dampeners to compliment the car.
Aegean303
Co
Civic Touring
I’ve been wanting to switch out the rear sway but would it be much of a difference if I get the si sway bar? I have a 2016 touring and I notice the size is 17.0mm and the si is only 18.0mm. Would the type r rear sway bar be a better choice?
derbo904
derbo904
Bay Area, CA
17 FK7 | 11 E90M3
Boring math will tell you its not a linear increase when changing the diameter of a sway bar. It is up to you if you think 133% stiffer is necessary.
(new O.D. sway bar ^4th power) divided by ( old O.D. sway bar ^ 4th power) then subtract 1 and multiple by 100 gets you the percentage.
17 --> 18 will be 26% stiffer.
(18^4/17^4-1)*100
17 --> 21 is massive 133% stiffer.
(21^4/17^4-1)*100
http://www.whiteline.com.au/docs/bulletins/Update BL-281.pdf
Honda Civic 10th gen DIY: Si or CTR Rear Stabilizer Bar on Normal Civic Sedan/Coupe/Hatch Screen Shot 2018-07-09 at 4.12.11 PM
Hondanickx
Nick
Belgium
Has anybody even looked if the rear subframe is capable of handeling a larger swaybar? Type r ,si and regular Civic rear subframes all have different part numbers.Don't Know if it's because of the different exhausts ,but might also be a stronger subframe.
L8apex
Southern Cali
2018 SGP Sport
Actually all the hatches share the same rear subframe. From LX, to Sport, to Type R. The front subframe part numbers are different. The sedans have 4 different subframe part numbers depending on trim level, and the coupes have 3 different part numbers.
L8apex
Southern Cali
2018 SGP Sport
Oh wait correction: 2018 part numbers for the rear subframe on the hatches are all the same: 50300-TGH-A01.
2017 part numbers have 2:
50300-TBC-A01
50300-TGH-A01
Still don’t know what the difference is, if any.
stevescivic
2017 Civic Type-R, 1990 CRX Si
Hey guys, if anyone is interested in how this is done my buddy and I tried to throw a video together showing the general steps. We didn't have great lighting and the car didn't have much clearance for us to get in there with a video camera to get close ups of the sway bar bracket or endlinks.
Here it is:
derbo904
derbo904
Bay Area, CA
17 FK7 | 11 E90M3
Here it is:
thanks for sharing @stevescivic !
stevescivic
Not a problem. Not the best vid I've made b/c it was a rather impromptu swap that we decided to film. Normally my videos are a LOT more detailed than what you see here but it nonetheless captures the key things the need to be done.
ajsti24
Jon
2018 STi Type RA, 2017 MB-AMG GLC43, 2019 Giulia
Installed my 10th gen Si Rear sway bar too: Install was good, just needed to lower down car (loaded) to the ground for me to install the bracket bolts and endlinks bolts, somehow the bushings are so tight, cannot move the bar freely up/down.
Honda Civic 10th gen DIY: Si or CTR Rear Stabilizer Bar on Normal Civic Sedan/Coupe/Hatch 55F4AAF0-F373-49BB-99DA-607440964037_zpslnqjycsu
Honda Civic 10th gen DIY: Si or CTR Rear Stabilizer Bar on Normal Civic Sedan/Coupe/Hatch DC8E928B-9E51-4DEE-A4D0-131518D41D80_zpsz8g7lxiz
Honda Civic 10th gen DIY: Si or CTR Rear Stabilizer Bar on Normal Civic Sedan/Coupe/Hatch D3C66EFE-58F7-4DA2-AF53-CD24757E5942_zpspuybj2iw
fc1.nick
Nicholas
Stockton
2020 civic si
I read the thread the whole way so, will the ctr sway bar kit fit an Si I see an extra stiffness but, I don’t mind it I’m thinking about the afe control sway bar set if someone wants to reference back.
derbo904
derbo904
Bay Area, CA
17 FK7 | 11 E90M3
It fits. Did you read the 1st post chart about stiffness changes?
