Chris Nait
I'm not sure what radio that model code is. Can you post a picture of it and the back where the connectors are?
I think you will need the stock amplifier in order to make sound, I bought the same one by mistake before, all the pin definition are different to none ampflier headunit.I mean, connectors, I thought it was optical but it’s not, so I will try that, Im also waiting for the adapters from 13. Thank you in advance.
No this is for the rear view camera to operate as it did with the original head unit that was in there. That is the reverse wire trigger to turn on the lights when in reverse gear. What that does is tell the new head unit that it needs to switch to the rear view camera on the screenThis step "- Route a wire lead from the 15th pin of the 32pin connector (between purple and red, and above pink and tan), to the interior fusebox (under the dash). Ideally, using one connector recycled from the Honda harness, just insert the metal pin into the cavity, until you hear the click. If you want to color-code as OEM, use a little green wire."
is only if I want to use the second usb port right???
Definitely not optical and yes you can splice that back together. make sure to isolate the conductor (center pin) from the shield (outer copper strands) I would recommend soldering the splices to ensure a solid connection and use electrical tape to cover your solder joints. solder and tape the inner conductor then the shield. tape over all tightly. this will keep the joint strong and less likely to break.I mean, connectors, I thought it was optical but it’s not, so I will try that, Im also waiting for the adapters from 13. Thank you in advance.
you also need this connect to the tuner unit. connect the blue wire from this adapter to the one you have. you also have to swap the position of where the pin is on this adapter so the OEM antenna signal is received by the tuner.Hello , please need help , just buy the adapter FM antenna but how i can connect the blue wire ?
after direct connect the FM doesn't work and and SCAN dis-active
Thank you man, Ive already installed it, now I am waiting for the adapters to arrive.No this is for the rear view camera to operate as it did with the original head unit that was in there. That is the reverse wire trigger to turn on the lights when in reverse gear. What that does is tell the new head unit that it needs to switch to the rear view camera on the screen
thanks so much but the main problem the old unite tuner port contain the blue wire connection , and the new OEM unit doesn't have as picture so how can i connect as per below photoyou also need this connect to the tuner unit. connect the blue wire from this adapter to the one you have. you also have to swap the position of where the pin is on this adapter so the OEM antenna signal is received by the tuner.
https://www.ebay.com/itm/Novosonics...cura-Honda-Factory-Radio-To-Ant-/272759711201
