It's like Matrix, Red or Blue Pill.
But According to the Service Manual You should use the red one.
The camera pins are the same, the only thing that you have to do is to feed the connector with the rear signal.
Are you changing from a 2DIN aftermarket unit to the Honda OEM 7 inch?
Is your rear camera original or aftermarket?
What you are doing is right.
C15 = Reverse Signal
C13 = Power to the camera
C14 = Ground for the Camera
C28 = Shield/Ground for the Video Signal (RCA Yellow Cable)
C29 = Video Signal
Forget
C31
C32
I'm not sure If you have to tell the HU that there is a camera hooked on the unit on the C16 connector. I'll check what kind of signal you'll need to feed this terminal with.
Hello I did in other way, here it is:Great! So did you just Grounded C16?
