I cant do anything with wifi . So i need before use temp hack then install permanentDo you need a temporary solution or permanent?
If you need a permanent solution I recommend you to use HondaHack, it allows to bypass the parking brake.
https://forum.xda-developers.com/android/general/guide-how-to-enter-developer-mode-2017-t3621582
The temporary solution is to change some settings on the diagnostics menu.
Why on my harness i dont have c3 and c11? Harness is from this head unit. I cut itThat's true. My Fault.
The problem is to remember the menu without the radio.
I'll check on the car later and post here.
My car was touring model. May be i download manual for another model. You have pinouts diagram for touring model?Depends on where did you get this diagram from.
All the diagrams that I'm posting here will match USA models, it looks like that matches your harness.
Yes im trying to put navi in acura RSX. All parts i take from 16 honda civic touringI think this diagram that I posted helps.
Your project is to Retrofit this Head unit in another car, right?
Do you already have all the parts? can you list?
You will have a lot of challenges but it's is an interesting project.Yes im trying to put navi in acura RSX. All parts i take from 16 honda civic touring
I havr fm/am module, rear camera, all harness, navi unit, gps antenna, usb cable, xm antena
thanks. Installed Honda Hack Pro but cant find bypass the parking brake.You will have a lot of challenges but it's is an interesting project.
Are you going to swap everything from a civic to a RSX chassis ?
But for the radio Basically you have everything.
I looked at the menu and try This:
I think after that you will be able to connect to Wifi.
- Press the power, menu, and brightness button at once, and hold until you enter a new menu with two options.
- Click the bottom option called Detail Information & Settings.
- Now hold the MENU key to enter another menu.
- Choose the Vehicle Model Information.
- Choose the Button DD VSP Error and Turn it to OFF.
If not you may need to change the model on another menu.
Is your head unit USA our from another country?
Just a Navi unit. RSX stock audio is a from `90`s))) Tape, Audio CD only))You will have a lot of challenges but it's is an interesting project.
There is a menu on the Honda Hack App.thanks. Installed Honda Hack Pro but cant find bypass the parking brake.
