DIY: retrofit Hondalink to LX/Sport
MFKilla
Alexander
Moldova
`20 Honda Accord 2.0T st.3 + `18 Honda Clarity
Do you have power on the 5pin connector fot he tablet display?
Trying with 10A power supply - still same. Dont work.
Can you check all needed wire again?
I connect
A3,A13,C10 +
A1 - ground
E4 - Display Count wire with 4pin on 5P display
1pin on dusplay 5P +
5 pin on Display 5P ground
MFKilla
Alexander
Moldova
That's interesting...
Can you provide photos of your actual Setup?
Do you have the LVDS going to the tablet display as well? Please check if the Attached PDF helps to check the wiring.
Yes. LVDS cable connected to MAIN UNIT and LCD
See picture for my connection.
Honda Civic 10th gen DIY: retrofit Hondalink to LX/Sport pinouts
MFKilla
Alexander
Moldova
you power on main unit with LCD display with AM/FM TUNER or without? I dont have AM/FM tuner yet. May be this is problem?
kotarou
Brazil
Honda FC2 - FFV
The FM Tunner module is not required to turn on the unit.
You don't need the C10 signal, this unit turns on without it.
Basically everything looks correct. It should turn on.
kotarou
Brazil
Honda FC2 - FFV
Any wire should be good. There is no need to use special ones.
As long everything is connected correctly is fine. When i was testing I was wiring the Tablet connector in the wrong order, so i do recommend to check everything again.
MFKilla
Alexander
Moldova
My Main Unit model number is 39101-TBH-A51. Its somithng matter?
jpixta
SLC Utah
2016 Honda Civic
As I remember should be JAE series AG5 terminals, but it didn't sell on amazon pretty hard to get only from AliExpress or Japan.
I found this site https://www.digikey.com/products/en...14b&quantity=&ColumnSort=0&page=1&pageSize=25
I bought my connectors off of here, I'm thinking one of these terminals will do the trick? I tried swapping another headunit in and it also doesn't work (again, stock headunit still works) so its got to either be the wiring or the actual connection.
Honda Civic 10th gen DIY: retrofit Hondalink to LX/Sport Wiri
Am I missing something? I am not hooking up the fm tuner.
Thanks everyone for the help!
MFKilla
Alexander
Moldova
look at my schema.
24P A1 not needed connect to 5P #5 pin. As 24P A3 in 5P #1 pin
You need add both wires to MAIN GROUND and MAIN 12v+
jpixta
SLC Utah
2016 Honda Civic
look at my schema.
Sorry I'm confused? The 24p a3 is continuous power correct? How would you go about doing what you suggest?
astrazinca
U.S
CIVIC LX SPORT
Hello i was wondering about to install new FM/AM adapter , seeking for the exact area for fixing but i cant found the 10p cable for connection , can any one guide me please for right location and installation
Honda Civic 10th gen DIY: retrofit Hondalink to LX/Sport IMG_7311.PNG
jdmsleepr
usa
2016 Civic LX
Here is the connector:
https://www.digikey.com/products/en?keywords=670-1814-ND
Here are the pins:
https://www.digikey.com/products/en?keywords=670-1785-1-ND
As for the OEM location of the tuner, it is in the rear quarter panel area on the left side i believe. Now i originally had it directly behind the new head unit and it worked great until i swapped in the EX cluster and had interference on the leads going from the head unit to the gauge cluster display. Tuner was outputting a lot of EMI and causing GPS to not lock location. I took out the glove box and moved it to nice spot there. Everything is working great now. Hope this helps
astrazinca
U.S
CIVIC LX SPORT
thanks you jdmsleepr for prompt reply will check for it and update
