DIY: PRL Motorsports Downpipe + Front Pipe Install
Kemptonic
Jacob
Bel Air, Maryland
2017 Civic Si Coupe
awesome write up man! This will probably be the first thing I do paired with ktuner and motor mounts.
Vtec_Nah
2018 Civic Si
Quick question, if anyone is still active on this post, Is the OEM heat shield still installed to the Catted PRL downpipe?
Vtec_Nah
2018 Civic Si
No that's only for type r down pipe
Thanks, wasn't aware. I've seen a couple or one other DP that was able to reuse the heat shield, will not having it with PRL's affect any components in the engine? IATemperature rises or something similar?
MacKharoni
Minneapolis
Honda civic 2000,2017 hatch sport
The heat shield help reduce the temp around your engine but nothing major. If u care I would just ceramic paint your DP. It will reduce the heat
Triple_peaz
Brother Taresa
Brandon
Louisiana
2019 Honda civic si sedan, 2016 Honda pilot
Just finished install today, thanks for the write. Only issue I had was this
Honda Civic 10th gen DIY: PRL Motorsports Downpipe + Front Pipe Install Screenshot_20190330-230000_Gallery
Triple_peaz
Brother Taresa
Brandon
Louisiana
Snapped it clean off will installing. So now I'm only on 3 bolts. Gonna have to get a tap set later and see if I can fix it. Other than that, perfect right up bro
jcivics
Manchester, New Hampshire
2019 Honda Civic Hatchback Sport
I had the lower left go out on me. I cut it off with a hacksaw, filed flat. Remove radiator upper support for more room to work with. Tap the center, drill through with 7/64” then 7/32” black oxide bits. Then do the 11/32” bit. It must be perfectly centered. Use M10x1.25 tap. I was a hair off on the drill and the M10 wouldn’t fit. Put a M8 though there with washers... better than nothing. Very frustrating.
I think you’re gonna have to take off your turbo to get to that one. I’m interested to know how you fixed it since it’s been 3 months from your post. Ty
