17CivicTypeR_Brian
- Oct 14, 2015
- 113
- 3,608
- 2,759
- York PA USA
- '17 Black CTR #4071, 16 MDX Tech
Without getting in to much of a story-
Tools needed-
Phillips head screw driver
Plastic trim popper (blade?)
10mm socket & driver
1. remove plastic trim which houses the switches by prying up at the front with the plastic trim popper
2. Unplug any connectors
3. Remove the 1 phillips head screw
4. Starting at the lower, forward corner of the trim piece, pull the panel off with a sharp, straight, outward motion. Work your way around
5. Remove the tweeter triangle by pulling outward. Disconnect the connector.
6. Separate the electrical connector for the side mirror.
7. Release the 3 10mm nuts from the side mirror. Take care that the mirror doesn't fall once you get the 3 nuts off (TWSS!)
8. Reinstall in reverse order!
Tools needed-
