DIY HID Projector Retrofit
  1. mcbacon
    mcbacon Senior Member
    Dec 26, 2018
    61
    Occupation:
    Tech Support Monkey
    Dallas, TX
    Vinney
    2016 Civic LX w/Sensing
    Do I spy amber on your high beam reflector? Nice work! Gonna pop in some 9011s?
    spaghettixsauce thanked this.
  2. jgklim
    jgklim Member
    Jun 15, 2018
    40
    2018 Honda Civic Sport
    this looks really cool. How did you tint the reflector yellow? Do you have a picture of how it mounts to the back of the projector?
    Thanks in advance!
  3. spaghettixsauce
    spaghettixsauce Senior Member
    Jul 7, 2018
    74
    79
    JP
    FK8
    I used window glass paint. I ended up not liking it and re-doing it black. As far as the projector, I don't have a picture of the new projector with the brackets mounted, but you can see the OEM projector here. You can see how the shield is the actual bracket as well. You'll end up disassembling the old projector and trimming the bracket so you can mount it to your new projector. It only mounts on the top and bottom of projector.
    Here are pics of how everything came out afterwards.
    RallyeRedSedan, Remm, fabster22 and 3 others thanked this.
  4. spaghettixsauce
    Jul 7, 2018
    74
    79
    JP
    FK8
    Ended up painted that portion black instead. The highbeam wasn't going to be used anyway since the projectors are bi-xenon. There were too many colors going on in the front of the car with the red emblem, yellow high beam, orange blinkers and blue projector.
    Remm and jgklim thanked this.
  5. jgklim
    jgklim Member
    Jun 15, 2018
    40
    This is simple, beautiful and super functional. STICKY
    Remm and spaghettixsauce thanked this.
  6. iShift_6
    iShift_6 Member
    Mar 10, 2018
    New Jersey
    Doug
    2017 Honda Civic Si Coupe WOP
    @spaghettixsauce that is a gorgeous retrofit!
    What paint did you use to paint the shroud black?
    I'm thinking about changing out my Bi-LED setup to what you are running or the new PJX Bi-LED.
    How do you like the Mini D2S 5.0? How's the width?
  7. spaghettixsauce
    Jul 7, 2018
    74
    79
    JP
    FK8
    I used duplicolor low gloss black engine enamel. Rated to 500 degrees so I figure that can't hurt.
    I like the setup a lot. I know the mini h1 is a more plug and play projector but the reviews of the d2s series made me choose that. The width is great. I don't have many projectors to compare it to but definitely better than the tsx and evo xr projectors.
    I didn't take very many good pictures yet but hope this helps .
  8. iShift_6
    iShift_6 Member
    Mar 10, 2018
    New Jersey
    Doug
    The output/color/width look amazing. Definitely better than the touring/R LEDs, and worlds wider than my current setup.
    And thanks for the info, time to rework my other set of lights o_O
  9. Nitroturtle
    Nitroturtle Senior Member
    Feb 4, 2019
    184
    133
    WV
    2019 PMM CTR, 2006 S2000, 2011 CR-V EX, 2007 Element LX AWD
    So
    So this is Mini D2S v5s, right? I just picked up my CTR this past week and compared to the older model D2Ss I put in our CR-V, the CTR lights are pretty meh. Was considering doing this eventually. Did you use OEM assemblies or DEPO/TYC? I have to get new assemblies as I don't even want to try to retro the factory CTR lights.
    Looks great BTW. Love the shallower step on the newer version. I have the previous version in the CR-V and the step is HUGE.
  10. spaghettixsauce
    Jul 7, 2018
    74
    79
    JP
    FK8
    Yes, they are Mini D2S 5.0s. once I get a few more decent pics I will try to make a separate thread. Unfortunately I didn't take too many pics of the install. Yeah don't try to retro the CTR ones lol, that will be a nightmare. The OEM LEDs aren't horrible, and will probably be more than enough for the average user, but once you've had a nice set of projectors or a good retro, it doesn't compare. I used a set OEM assemblies but I supposed the Depo will work just as well.
    himecraig, Remm and Nitroturtle thanked this.
  11. NHCivicGuy
    NHCivicGuy Senior Member
    Oct 10, 2018
    726
    412
    NH
    2019 Si
    What bulbs are you using in these pics?
  12. Nitroturtle
    Feb 4, 2019
    184
    133
    WV
    So I'm reading through this again and really thinking I want to do a retro myself. For the mounting, did you just shave off the shielded part of the stock brackets to allow for the Mini D2S to shine through completely? How was the alignment process? Do any of the factory mounting points line up or do you need to do a manual horizontal alignment? That's the part I always hate, because I prefer to mount them to align, which means installing the lights a few times.
  13. spaghettixsauce
    Jul 7, 2018
    74
    79
    JP
    FK8
    Osram CBB
    NHCivicGuy thanked this.
  14. spaghettixsauce
    Jul 7, 2018
    74
    79
    JP
    FK8
    I used the stock shield/bracket. Cut the whole inside of that piece and made holes that will match the projector. With that bracket you can use the OEM mounting points. As long as the projector is mounted to the bracket straight, you shouldn't have any issues with alignment. I got it right the first try. Take a look at this image. This image isn't mine, but is another member's who I helped with his retrofit. He was patient enough to take pictures lol. This is the way I did it. Thanks to @airickmatthews for the pics.
    jopale, airickmatthews and Nitroturtle thanked this.
  15. airickmatthews
    airickmatthews Senior Member
    Mar 7, 2017
    563
    212
    Ruskin fl
    17 civic hatch sport
    Ayyy.. that look familiar. Lol just take your time shaving the stock cut off shield. It’s not difficult, but it sure it super time consuming.
