DIY HID Projector Retrofit
  1. FK7Hatch
    FK7Hatch Senior Member
    Jan 4, 2017
    258
    155
    MD
    17' Civic Hatchback Sport
    #1 FK7Hatch, Apr 3, 2017
    What you'll need:
    • HID Projectors ( ILX, 09-14 MDX Should be direct fit), however with imagination you can make any 2.5" projector fit. I used projectors from a Maxima.
    • Oven or Heat-gun
    • Flat and phillips screwdrivers
    • Spare Headlight housings (Optional but advised, I used TYC housings)
    1. Remove all the bulbs and rubber seals from the headlight. On the back of the headlight, there will be screws that go into the lens like pictured below, remove all these screws around the perimeter.IMG_1308.JPGIMG_1307.JPG
    2. Once done, place your headlight in the oven on the middle rack on some 2x4s for 10 mins at 200 degrees F. (I used a heat gun)
    3. Remove the headlight from the oven, and start to work your screw driver under the lens starting at the high beam, and working your way towards the turn indicators, eventually the lens will come up enough that you can pry the two haves apart by hand. (This step takes patience, if you don't get it the first time, put them back in the oven to loosen the glue and keep trying).IMG_1310.JPG
    4. Once you have the lens off, remove the four phillips screws holding indicator and the DRL LEDS in, carefully unplug the DRL wires from the PCB.IMG_1311.JPGIMG_1312.JPG
    5. Now flip the headlight over, and back the headlight adjuster screw all the way out.IMG_1313.JPG
    6. Now turn the headlight around, and release the four tabs used to hold the headlight bracket it on both ball joints.
    7. Remove the Headlight Bracket from the Assembly
    8. There are four screws holding the projector onto the bracket, remove these four screws.
    9. Remove the Halogen projector and replace it with your HID Projector. (Depending on what projector you use, you may need to modify or create brackets to mount the projectors.) Once you do so, insert a bulb and fire on the bulb inside the projector to check your rotation is perfect. You'll see below I had to drill and cut the factory mounting points on these Maxima Projectors in order to mount them.
    10. Once thats done, put everything back together in reverse order, mount the lights on your car to verify correct rotation and make adjustments before you put the lens back on and into the oven!!
    11. Mount the headlights onto the car, and aim your headlights accordingly. from 25ft from the wall, they should be about 2" lower than the height to the center line of your projectors of the ground.
    Final Results:
    hon da, Remm, jgklim and 10 others thanked this.
  2. Swordfish
    Swordfish Senior Member
    Feb 16, 2017
    735
    301
    Los Angeles, California
    2017 Honda Civic
    Awesome !
  3. OP
    FK7Hatch
    Jan 4, 2017
    258
    155
    MD
    Someone on here said that the Maximas were bolt in projectors, so when I saw a pair for cheap, I jumped on it.
    I got rid of stock halogens two weeks into ownership, they sucked. Compared to the hid kit I had in their before, you'll notice the light is wider and more evenly dispersed. I also notice that it looks dimmer than the hid kit because of how it has less foreground lighting, however because of this I'm able to look further down the road.
    Theory816 thanked this.
  4. Snoopyslr
    Snoopyslr Senior Member
    1,856
    2,091
    Occupation:
    CAD Designer @ General Motors
    2016 Honda Civic EX-T, 2003 Subaru Impreza WRX
    Pretty awesome that they bolt right in. No adjustment or tweaking needed. Nice work
  5. OP
    FK7Hatch
    Jan 4, 2017
    258
    155
    MD
    lol I wish, these required me to cut off parts of the bracket, and the projector mounting holes and drill a bit to bolt them right up
    Snoopyslr thanked this.
  6. Snoopyslr
    1,856
    2,091
    Occupation:
    I see it now on the top in one of the pictures. Still, as far as retrofits go, this is a super clean install. I'm hoping to get a bunch done on mine today and this weekend.... Life is getting in the way again. This is why I bought a second set of head lights... I knew it would take me forever to finish lol
  7. OP
    FK7Hatch
    Jan 4, 2017
    258
    155
    MD
    Yeah, it could've been worse with JBWeld and loads of silicone hahaha. I was just lazy, it would've taken me longer if i decided to make custom shields to go with the clear lenses.
  8. Snoopyslr
    1,856
    2,091
    Occupation:
    So I got a lot done with mine yesterday.... and it's not good. Bolting the FX-R in made it sit farther back than the OEM lens, so after I re-assembled everything it looked ridiculous. I ended up cutting the adjustable mounting bracket in half and bonding on a piece of carbon fiber sheet I had laying around. I'll re-fit the bracket back into the ball joints and threaded adjustment, then cut out a hole for my FX-R to mount too. What sucks now, I have to mount the headlights into the vehicle to get the roll orientation correct before fixing the lens to the bracket.
    Bottom line... FX-R is not a good lens for an easy install.
  9. OP
    FK7Hatch
    Jan 4, 2017
    258
    155
    MD
    Those things have always been a pain to retro haha, sucks, but good luck dude!
  10. jluff007
    jluff007 Senior Member
    Feb 9, 2017
    60
    Portland, OR
    2015 Toyota 4 Runner Limited, 2017 Honda Civic HB Sport
    Do you have a link for the TYC housings you used? i want to do a retrofit like this. but i dont want to tear apart my factory headlamp. I haven't attempted something like this yet and i would hate to screw it up too bad. Maybe i should just find a nice set of HID's to put in the stock housing. :/
  11. OP
    FK7Hatch
    Jan 4, 2017
    258
    155
    MD
    I got them off rock auto
  12. choo
    choo Senior Member
    Dec 10, 2016
    307
    114
    FL
    '17 Hatch Sport 6MT , 240SX's
    What year Maxima projectors are those? I have a set of working headlights from an '04, hoping I could use them.
  13. OP
    FK7Hatch
    Jan 4, 2017
    258
    155
    MD
    These are the newer Maximas, I believe the last gen before they went to LEDs
  14. Shankmeyster
    Shankmeyster Senior Member
    Mar 15, 2017
    2,699
    1,261
    AZ
    2017 Civic Sport Hatch 6MT
    #14 Shankmeyster, Apr 26, 2017
  15. yamin1021
    yamin1021 Senior Member
    Oct 31, 2017
    88
    40
    cn
    2016 civic ex
    Hello, how's TYC compare to OEM ? Thanks
