MtnBikeAZ1
- Oct 7, 2018
- 4
- 55
- 80
- Tucson AZ
- 2018 Civic Si Coupe
I wanted to install cargo hooks in the trunk of my Si coupe, but Honda doesn't make it easy since they didn't put the right holes in the coupe like they do in the sedan. First I want to give credit to the folks that posted in this excellent thread: https://www.civicx.com/threads/diy-trunk-cargo-hook-install-without-using-the-rivet-nut.1414/page-2
So why another thread? First, the other thread is older and the picture with the correct hole circled in the coupe's trunk doesn't show up anymore. Second, I had some time on a rainy afternoon to be a little more creative with the install - I wanted to ensure the hook couldn't twist in the mount with usage.
1. Here's the correct hole to use on either side of the light, it's the one you can see the fender washer with two holes in.
2. I used the "thick" 1/4" x 1-1/2" fender washer as opposed to the thin fender washers.
3. Thread the bolt that comes with the kit thru the cargo hook, then thru the fender washer. Mark the place where the little "nub" on the cargo hook that keeps it from spinning hits the fender washer.
4. Drill a hole in the fender washer at the marked location.
5. Test fit the cargo hook to the washer.
6. Put the Spring Washer on the bolt and then the Large washer (both from the kit) and thread through the cargo hook so its ready to install.
7. The hole in the fender washer keeps the hook from turning, but I wanted to ensure the fender washer couldn't turn so I put some all purpose adhesive on the fender washer to keep it from turning. This type of adhesive takes about 5 minutes to set up which gives you time to finish the install.
8. Place the fender washer behind the correct hole as shown in the earlier photo.
9. I used a M6 x 40 Keps nut which has the built in star washer to keep the nut from rotating loose. Tape it to your 10mm wrench.
10. Put the wrench thru the slotted hole in the trunk and line up with the center hole in the fender washer.
11. Start the cargo hook bolt, once it catches, line up the washer so that the small hole you drilled faces the back of the car (as it would if Honda had given us the right holes).
12. Tighten down bolt before the adhesive sets. Remember to remove your wrench.
13. Laugh as you throw away Honda's Rivet Nut!
14. Go shopping and use those new cargo hooks!
