DIY: Adding turn signal Lights to Si/EX side mirrors
  1. OP
    Blacklude4
    Blacklude4 Senior Member
    Apr 10, 2017
    165
    240
    Washington
    1993 Prelude VTEC, 1990 Civic EX hatch, 2018 civic Si coupe
    Still no luck on pins for your retracts!? Do you have a picture of one of them outside of the plug housing? I can't recall what they looked like.
  2. 17CivicTypeR_Brian
    17CivicTypeR_Brian Aiming for 400whp out of the TypeR.
    Oct 14, 2015
    3,606
    2,750
    Occupation:
    Mech Eng acting as Electrical Project Engineer
    York PA USA
    No luck! I made it work using parts from CycleTerminal - I reterminated the mirror-side and the door-side so it plugs-and-plays but still not OEM.
  3. Si_chRis
    Si_chRis Senior Member
    Jul 10, 2017
    79
    71
    Connecticut
    2000 Honda Civic Si, 2018 Honda Civic Type R
    I've been researching a lot looking at many threads, and this is just what I was looking for. Thanks for sharing!
    Dan0974 and 17CivicTypeR_Brian thanked this.
  4. raf702
    raf702 Senior Member
    Aug 13, 2019
    145
    48
    Ralf
    2016 Civic LX-P CVT
    How about installing this without the lane camera. Can the same parts w/o lane watch, and install process work the same? Since I have a LX-P Coupe.
  5. Si_chRis
    Jul 10, 2017
    79
    71
    Connecticut
    It seems you'll just need the housings that don't have lane watch, but have the provision for the turn signals.
  6. raf702
    Aug 13, 2019
    145
    48
    Ralf
    2016 Civic LX-P CVT
    That’s what I was thinking. Install seems a bit tedious and intensive though.
    I actually found some aftermarket led side mirrors on eBay. Looks to be plug n play, based on the mirror. But mentions something about having a 7-pin plug. I have no idea if mine has that or what.
    Not a need, but a want. Seems like a cool mod to have for my GenX.
  7. Si_chRis
    Jul 10, 2017
    79
    71
    Connecticut
    If your mirrors are only power adjust, they most likely have a 4 pin connector. My CTR mirrors only have power adjust, and when I once had the door panel off, I only saw a 4 pin connector for the mirror.
    Overall, if you're looking to add the OEM turn signals with new housings as shown in this DIY, your 4 pin connector would be unchanged, and you would only be running two additional wires from the mirror housing that is not part of the 4 pin connector.
  8. raf702
    Aug 13, 2019
    145
    48
    Ralf
    2016 Civic LX-P CVT
    I appreciate that info, the 2 additional wires I assume are the power and ground for the LED light ?
  9. Dan0974
    Dan0974 Senior Member
    Jun 8, 2017
    248
    207
    Occupation:
    Software Engineer
    White Marsh, MD
    Supercharged 2009 Civic Si, 2017 ABM Civic Type R
    #24 Dan0974, Sep 12, 2019
    Yes, that’s how I did mine. The turn signals I purchased from AliExpress came with the bottom portion of the mirrors, led turn signals and wire harnesses (just positive and negative wires for each side). My factory front part of the mirror on my ctr didn’t have the cutout for the turn signals so it looked a little funny. I ordered the touring mirror housing for the left side and the euro ctr housing for the right side because the euro ctr doesn’t have lane watch.
    17CivicTypeR_Brian and raf702 thanked this.
  10. 63blackseries
    63blackseries Senior Member
    Nov 23, 2017
    88
    Ray
    2017 Civic EX Sensing
    I found these but i have lanewatch so not sure it will work.Screenshot_20190912-163957_eBay.jpg
  11. Dan0974
    Jun 8, 2017
    248
    207
    Occupation:
    Software Engineer
    White Marsh, MD
    The US sport touring’s come with camera and turn signal you can just order this part # for the right side:
    76205-TEC-Y11 (does not include the led itself, this is just the housing)
  12. raf702
    Aug 13, 2019
    145
    48
    Ralf
    2016 Civic LX-P CVT
    These are the lights I was seeing on eBay as well. Apparently the driver side mirrors are out of stock, just passenger side available.
    I’m assuming these mirrors provide power for positioning the mirror element as well as heating/defrost.
    In my case I only benefit from the electrical portion of positing the mirror element. Since mine doesn’t have the defrost feature.
  13. Dan0974
    Jun 8, 2017
    248
    207
    Occupation:
    Software Engineer
    White Marsh, MD
    This is the list of the items I ordered:
    1. Turn signal mirrors (about $40): [https://s.click.aliexpress.com/e/CD2xdlpe](https://s.click.aliexpress.com/e/CD2xdlpe)
    You can 100% just use these if you don't mind the front of the mirror not having the cut out for the leds
    2. Left factory mirror housing (about $30 shipped): Honda Part # 76255-TEK-M01. Can be ordered from anywhere but I purchased mine from bkhondaparts.com
    3. Right factory mirror housing:
    76205-TEK-M01 (about $50 shipped) - no lane watch must be ordered from Europe.
    76205-TEC-Y11 (about $88 before shipping) - sport touring mirror cover with lane watch can be ordered from any dealership.
    63blackseries thanked this.
  14. 63blackseries
    Nov 23, 2017
    88
    Ray
    Thanks for the part numbers Dan!
    Then i found these on ali express, what do you guys think? I may want mine color matched tho instead of carbon.
    https://h5.aliexpress.com/item/4000...g0n.seo-amp-search.searchResult.4000053163401
    Dan0974 thanked this.
  15. Dan0974
    Jun 8, 2017
    248
    207
    Occupation:
    Software Engineer
    White Marsh, MD
