DIY AC Condenser Replacement?
  1. Olmsteez
    Olmsteez Member
    Dec 4, 2016
    26
    NJ
    17 EXT Hatch
    I have a 17 Civic Hatch with a confirmed condenser failure. The stealership says I'm not covered under the condenser TSB. And my local AC shop says they can't find one in stock anywhere. I see a couple of different ones in stock at RockAuto. But, they won't install parts that I provide. I'm thinking about doing it myself and having my shop do the recharge. The stealership says my system is completely empty of refrigerant. So, no environmental issues there
    Hoping someone has done this already and can share any shortcuts or things to look out for.
  2. Mocha90210
    Mocha90210 Senior Member
    Jan 15, 2016
    707
    364
    Did they say why you aren’t covered under the TSB? Is the car older than 3 years? If not then you should be covered under warranty too. The only exception is if there is damage to the condenser from a rock or something.
