Did I just get ripped off at dealership? $350 for a B-1-2-7 service. '16 Civic EX 26000Miles
  1. Yeah!!
    87.7%
  2. No, this is about what the B-1-2-7 maintenance should cost.
    12.3%
  1. julianzh
    julianzh Senior Member
    Apr 1, 2016
    380
    137
    Quincy
    2016 Civic EX-t
    https://www.amazon.com/dp/B000CO86BY/ref=cm_sw_r_cp_api_aD.RAb80BTQD6
  2. dc2turbo
    dc2turbo Senior Member
    Jan 27, 2016
    2,921
    2,032
    usa
    civic,teg
    if you are just doing front to back etc. you can jack up the whole side of the car if you put your jack by the front door jack point
  3. maddmatt02
    maddmatt02 Senior Member
    Jan 11, 2017
    865
    505
    marysville, wa
    2017 civic ex-t 2016 crv lx 2001 accord ex 1997 integra gs
    I actually have 2 Jack's now and Jack stands, was partly referencing most people with only one jack and partly the fact that I still have to one by one lift corners. I have assymetrical tires (pretty sure that's the term) not directional so I get one side up and swap front/back, other side up and move front to back then let the rear down and bring back the other side front and swap L/R. I've gotten it down to a pretty quick rhythm and don't have to do it very often anyways.
    Snoopyslr thanked this.
  4. latole
    latole Civic Lx 2018 Manual , Civic LX 2016 Manual
    Apr 13, 2017
    1,953
    432
    Vaudreuil,Quebec ,Canada
    It's worth the price to buy some jack stand than to go to the dealer. Jacks stands paid by itself.
  5. Snoopyslr
    Snoopyslr Senior Member
    2,155
    Occupation:
    Engineering Technician
    Unidirectional :p
    Having 2 jacks is really a great thing for anybody doing lots of work themselves. I've got 2 of the cheap ones from Harbor Freight and I find myself using the second one a lot.
  6. maddmatt02
    Jan 11, 2017
    865
    505
    marysville, wa
    Just looked my tires up to be sure. I have assymetrical like I thought, they look pretty close to symmetrical though but either one can go all 4 corners. Last time I had directional tires and could only go front to back the cheap person inside of me always felt I was losing tire life by not being able to rotate to all corners... I finally bought the nice low profile rapid pump 3 ton I think Jack, it's real nice after using the cheap $20 2 tonners that come in the kit with stands
  7. latole
    Apr 13, 2017
    1,953
    432
    IMO when we install new tires on a car ,they should be stay on the same side of the car with rotation. Never on 4 corner.
    Left front tire can go on on left rear wheels not right side.
    It is because they are radial tire.
  8. choo
    choo Senior Member
    Dec 10, 2016
    316
    124
    FL
    '17 Hatch Sport 6MT , 240SX's
    Changing brake fluid at under 30k miles....lol. That stuff lasts like 10 years at least.
  9. maddmatt02
    Jan 11, 2017
    865
    505
    marysville, wa
    I've heard that but in my 17 years of going all 4 corners and 25 years of watching my dad/grandpa/uncle go all 4 corners I've never had, or heard of them, having a problem. I always send the drive wheels straight and the others diagonal.
  10. latole
    Apr 13, 2017
    1,953
    432
    I agree, never change it on any of my cars, more than 10 years each with more than 100,000 miles.
  11. Soamazen23
    Soamazen23 Member
    Jun 15, 2016
    37
    Orlando, FL
    CivicX EX
    Definitely...
    Coming from someone that has worked at a dealer for 5+ years. I will only take my car in if something breaks and its covered under warranty. I have and will continue to take care of every single aspect of the maintenance spectrum. There are several things that could be done to save money. 1. Being ask for these services separate. 2. Would be to take care of some items yourself. Changing filters does not require an engineering degree. It literally takes 30 seconds or less to change your cabin and engine air filter. Use your resources. We can all learn a lot from websites such as these. Save yourself some money it'll add up in the long run.
    david1pro thanked this.
  12. TypeSiR
    TypeSiR Senior Member
    May 15, 2017
    1,298
    876
    Occupation:
    Car Driver
    1.5T Civic, CTR, MX-5, Fit
    Got a similar A127 maintenance code as well on a 2016 EX-T. Basically replace engine oil, air filters, and brake (!!!) fluid. Had to look up the 7 code (change brake fluid every 3 years?) Not going to the dealer no matter what. Will have my mechanic take care of the brake fluid for far less. The rest I can do myself.
  13. a c i d.f l y
    a c i d.f l y Senior Member
    Sep 25, 2017
    698
    327
    Austin
    What kind of brake fluid or brake system are they using that would require a 3 yr flush? I only ever had to do that on a 10yr+ vehicle that had gotten contaminates in the line via faulty master cylinder seal, or shitty brake fluid that had coagulated. A sealed system with DOT4 synthetic should last basically the life of the vehicle. If fluid is leaking or air getting in the lines, the seal somewhere is bad.
  14. typemismatch
    typemismatch Senior Member
    Jun 15, 2017
    970
    910
    Occupation:
    Software development
    Fargo, ND
    Russell
    A whole farm of Hondas
    $350 is steep, no doubt.
    I take my daily to the dealer for a couple reasons.
    1) If I turn a wrench on it, I'll need another daily (the mod bug is strong in me)
    2) If I get into an accident, all of the maintenance is logged in the dealers files. Condition and maintenance got me quite a bit more from insurance when my FG2 was totaled.
  15. JoeShades
    JoeShades Senior Member
    Jun 23, 2017
    100
    Williamstown , NJ
    Joe
    2018 Civic EX-T Sedan
    I had my 01 civic 17 years 152,000 miles never changed brake fluid
