Did I goof my break-in?
  1. timeatak
    timeatak New Member
    Aug 25, 2018
    Wisconsin
    Jimmy
    2018 Si White Sedan
    Bought a new Si with 15 miles on it. I did some spirited driving right off the lot. Not like bouncing off the rev limiter or massive clutch dump launches or anything. But I did do quite a bit of quick accelerations, and bringing up the RPM's up just before red line to shift. Was just doing this occasionally, to get a feel for what the car had to offer.
    The dealer told me nothing about a break in period. I only found out about this through research. If I have damaged something, what would it most likely be?
  2. repeet
    repeet Senior Member
    Jun 3, 2017
    538
    482
    Occupation:
    Retired
    Fort Mill, S.C.
    '17 Civic Si Sedan
    When I bought my Si, the dealer told me that there wasn't any "break in", and to drive it like I wanted to.
    The Owners Manual says that there is a 600 mile "break in" period where you shouldn't push it past 4k, and to try to keep varying the RPMs.
    I wouldn't sweat it too much, if the car is running ok, your probably golden. Just take it easy for the 600 miles. I spent my first day with my Si driving the back roads from town to town in order to exercise my engine properly.
    Leetcivx and timeatak thanked this.
  3. 360glitch
    360glitch Moderator
    3,710
    3,589
    2017 Civic Si Sedan
    No damage is likely, but you’ll want to stick to the break in protocol going forward.
    thatonedaveguy and timeatak thanked this.
  4. coleman17
    coleman17 Guest
    I knew about the break in period but would still have a little fun here and there. You likely won't have any problems, just take it easy from here on out. On the test drive, the dealer even encouraged me to "floor it" and "see what she can do". Obviously, a salesman probably doesn't care, he just wants you to like the car and buy it,
  5. Ataricade
    Ataricade Senior Member
    Feb 6, 2018
    703
    388
    Midwest
    2018 Civic Si
    Don’t give it another thought you are fine.
    Leetcivx thanked this.
  6. Superfly
    Superfly Senior Member
    Jul 21, 2018
    522
    584
    Central Pa
    D
    2018 Civic Type R / 2018 Civic Si Sedan / 2018 Civic Si Coupe / 2018 Acccord 2.0 Touring / 2001 S2000
    Drive it like you stole it! No worries, just do your 1st oil change at 1K. Happy driving!
    sgtmorph thanked this.
  7. MuffinMcFluffin
    MuffinMcFluffin Senior Member
    Jan 15, 2018
    383
    172
    Elk Grove, CA
    Brandon
    1999 Honda Civic EX, 2019 Honda Civic Si
    I have a different sort of question regarding break-in:
    So those first 600 miles should be varying the gears and RPM's and such, but what if you buy it and make a 600-mile road trip all in 6th gear?
    What I'm really asking is: did I mess up my break-in period, or could I sort of just treat it like "I still haven't done the break-in period yet, and if I vary my driving for the next 600 miles then all will be good." ??
    I hope that makes sense.
  8. charleswrivers
    charleswrivers Senior Member
    Nov 3, 2017
    2,563
    2,663
    Occupation:
    EMNCS(SS)
    Kingsland, GA
    Charles
    '14 Odyssey EX-L '18 Civic SI Sedan '94 300zx twin turbo 2001 Ford F-150 Sport
    It does to me...
    If you bought your car at a dealer 600 miles away and drove it on the interstate, sitting in 6th gear the whole way essentially... they you didn't do many gear changes to break in the clutch and bed it to the flywheel. You likely didn't use the brake much to bed the pads into the rotors. Vit did stick a brand new '17 Si on his dyno and ran it on 87 octane, then had it slip it's clutch running 93 octane. It was well inside it's break-in period, however.
  9. MuffinMcFluffin
    Jan 15, 2018
    383
    172
    Elk Grove, CA
    Brandon
    Okay, so I know it doesn't break it in then, but did I essentially "ruin" my break-in period? Or would I just have to still spend a bunch of miles driving in the city to balance everything out afterward and I'll be good?
  10. Ataricade
    Feb 6, 2018
    703
    388
    Midwest
    2018 Civic Si
    Hardly anyone follows any kind of break in on new vehicles. You will be fine
  11. charleswrivers
    Nov 3, 2017
    2,563
    2,663
    Occupation:
    EMNCS(SS)
    Kingsland, GA
    Charles
    No, I wouldn't consider it ruined. I'd say that because some cyclic things didn't happen so much based on your driving style... it's just going to take longer to get things, like your clutch getting bedded, to happen. I don't think, in any way, anything is 'ruined'.
    MuffinMcFluffin thanked this.
  12. BIGBLUESI
    BIGBLUESI Senior Member
    Sep 19, 2018
    194
    70
    New York
    2018 Civic SI Coupe
    You should be OK. Just go easy as others have mentioned above.I went a little bit higher on the RPM recommendation with 300 miles and no problems.
  13. VooDuuChild
    VooDuuChild Senior Member
    Aug 31, 2018
    382
    246
    Occupation:
    Professional lawnmower racer.
    Westsiiiiiiiide
    2018 Civic Si, Boosted Street and Track Monster 91 CRX Si.
    It's probably totally ruined. I will take it off your hands.
    B0nez and Leetcivx thanked this.
  14. MuffinMcFluffin
    Jan 15, 2018
    383
    172
    Elk Grove, CA
    Brandon
    Thanks, asshat.
    I didn't ask if the car was ruined. I was asking if one falters the break-in period by not mixing up the driving. Everywhere they say to vary things like the RPM's, speeds and gears, but they don't say what happens if you don't. In other words, does it just "delay" the break-in, or are you going through that period and not doing as suggested without any possible reproach?
    And responses such as yours or "people don't break in engines" are not helpful to what it is that I'm asking.
  15. Blindeye_03
    Blindeye_03 Senior Member
    Jan 23, 2016
    277
    178
    Occupation:
    Aviation
    Northern Kentucky
    18 SI sedan
    • During the first 600 miles (1,000 km) of operation, avoid sudden acceleration or full throttle operation so as not to damage the engine or powertrain.
    • Avoid hard braking for the first 200 miles (300 km). You should also follow this when the brake pads are replaced.
    Straight from the owners manual.
    Also its more for the clutch than for the engine.
