Dealer said my brakes need to be replaced next visit. Is this a realistic quote??
kilo959
J
Atlanta, Ga
2018 Civic Type R; 1995 Nissan Hardbody
Took my car in yesterday for an oil change, new wiper inserts and to put my all season tires back on since the weather is far too cold for summer tires now. Dealer said my brakes have 3-4mm left on them and will need to be replaced next service visit.
He gave me quotes just so I knew what to expect. Are these REALLY that expensive?
Brake Rotors/Discs and Pads - Front - Replace - $871.95
Brake Rotors/Discs and Pads - Rear - Replace - $628.42
$1,783.50 in total before taxes. This is almost $2k for brakes.
Are these realistic prices? Is typical dealer markup thrown in there?
That's dumb. I'd find a new dealership.
ez12a
CA
18 CW Type R
Rock Auto has the OEM Brembos for $87/pc. currently.
PEPSIFLAME
Dallas, TX
2020 Honda Civic EX Hatchback
DIY this job. Changing your brakes is part of owning a car. It's pretty quick and semi-easy. Your rotors most likely don't need to be changed. Hit up AZ and get pads.
BABY NSX
Phil
Boston, MA
2019 Honda Civic Type R, 2019 Toyota Sienna, 2006 Toyota Highlander, 1972 Dodge Challenger Rallye
Here is a link to my online journal...i’ve posted a detailed step by step writeup complete with photos regarding rear brake pad, front brake pad and rotor change. Including the EPB disaster I ran into. Will post a brake bleed write up as well:
https://www.civicx.com/threads/fatherpain’s-2018-type-r.42379/
If interested, Scroll to the bottom of page 1 then see page 2.
This was the first time I’ve done brakes for any car, so was a learning experience. Now ready to do the job from here on out.
Awesome journal, thanks!
I agree as everyone said, the OP got a quote way too high from that dealer.
Sorry, not to go too far off topic but I noticed in Fatherpains journal that an Autel device is used to get the car in “brake maintenance mode”. I didn’t see anyone else mention that? Is this necessary to do the rear brakes or can you just remove the rear calipers and spin in the piston? Thanks!
ez12a
CA
18 CW Type R
People have differing opinions on this, but if you go by the service manual:
1. you need to either use a OBD tool to put the brakes in maintenance mode.
OR
2. Remove the ebrake actuator from the rear caliper and retract the ebrake spindle back manually with a torx E11 socket, then push in the piston. This is known as a "forced cancellation"
People have replaced their rear pads without doing #2 and just pushing in the piston without problems YMMV though.
fatherpain
Tom
BABY NSX
Phil
Boston, MA
Thanks guys for info!!! :thumbsup:
Mick the Quick
Mick
Southeast MA
2018 PMM Civic Type R (R-08508)
codeBoss
Richard
Raleigh, NC
2017 Si Coupe; 2019 CTR
Why are we talking about replacing rotors and not just resurfacing them?
yes all CTRs groove (especially the front) so why not just resurface and move on. Never had a car that couldn’t get at least 2 resurfacings before replacing....unless there was some other issue.
willskiGT
Atlanta
2019 Civic Type R #26262
This thread has been about replacing rotors at the end of their service life.
There is no point in resurfacing rotors on the CTR simply because they are grooved, since:
1. The grooving does not impact braking performance at all
2. The brakes will re-groove in under 1000 miles of daily driving
3. Resurfacing reduces the heat capacity of the rotors
4. Stock rotors are super cheap (~$90 for the fronts)
5. Most places will not resurface cross drilled rotors anyway
willskiGT
Atlanta
Update: Car is at 7600 miles, took it to the dealership for an oil change today. Usually, I would do it myself, but have a track day tomorrow and won't have time before I leave this evening to get it done.
Service manager calls me to tell me my rear pads are at 2mm and urgently need to be replaced. They are actually somewhere between 6-7mm (I know because I checked to see if they needed to be done prior to tracking the car). Why do dealerships feel the need to lie like this? I just don't get it.
Quote was $260 for rear pads + labor. Absolutely ridiculous.
fatherpain
Tom
Hmm. That makes wonder where I’m at with my stock rear rotors... I’m almost to 29k miles. Will check once I pick up a micrometer..
willskiGT
Atlanta
They also only put 5qts of oil in, so I was 0.7 qt low. Never again.
stingray
Phoenix
2016 Civic LX-P Coupe, 2013 CR-V
Do it yourself. If you don't know how, watch a You tube video. Easy and cheap.
Conika
Jason
Hickory NC
2020 Civic Si
I know this is an old thread but for anyone who sees this on the front page.
I would challenge you to watch this video and do it yourself. You can legit buy a tool set that would do this task, the jack stands to hold your car up, and the pads / rotors for a fraction of this cost.
you can go here and see what part number fits for your model and order from Amazon.
https://www.powerstop.com/
