Dashboard full of warning lights after light snow drifting??? Help?
Craiglane772
Craig
2018 Honda Civic hatchback Ex
On multiple occasions I’ve done light drifting in the snow while there is no issue in drive, in reverse I have about two or 3 good 180’s before I get a dash full of lights saying everything from tire pressure to ABS and brake problems and everything in between you can imagine... my question is does anyone have any ideas on what I should do because when it happens it seems that the car is fine and nothing happened mechanically just in the computer please help
shoegazer
Raleigh NC
2018 Civic LX Coupe 2.0 (CVT)
My hunch is that something got wet. Open the hood, put a fan on it, and hope for the best.
Good luck.
boibuddha
Vancouver
2018 Civic Si
You're fine. The wheel speed sensors were confused with your drifting in the snow.
They are used to seeing your wheels going all the same speed, but your snow burnouts messed that all up. Just keep on driving it'll go away after a while.
Frozen Gnome
Northern Ontario
2010 Honda Fit, 2015 Honda Odyssey
This is likely the case. Your wheel speed sensors detecting large wheel speed variation/ lockups will trigger TPMS, ABS, VSC, and traction control lights. Driving it for a bit should reset the sensor and turn off the lights. If that doesn't work you used to be able to short the obd port to force a reset on older Honda's but you might need a dealer tool to reset the system now.
Craiglane772
Craiglane772
Craig
Thanks makes me worry slightly less still annoying that everytime I wanna mess around that I’m gonna have a dash full of lights and no traction control till they turn off again but thanks anyway
aighead
Dayton, OH
snortcoffee.com
2017 Civic Si, 1988 Ford f250, 2004 Honda vtx1300
Do you have the dumb e-brake button? How are you drifting successfully? I'll take all the lights temporarily to have some fun!
jred721
James
Northern Virginia
'20 Accord Sport
Turn off the TC, the ice/snow naturally makes the tires slip which makes the car go sideways. Give it some throttle in the spin and you're "drifitng". For extra fun, turn the TC all the way off by doing the pedal dance, maximum smiles per gallon are achieved by doing this.
odinist
Matt
OKC
www.mithgarthr.com
2018 Aegean Blue Si Sedan
I've never done the pedal dance... I'll have to try it out sometime.
You'll honestly be surprised with how much of a difference it makes when it comes to acceleration. It's not like, tune difference, but it really feels like a different beast.
Dis4Damion
Damion
MA, USA
2019 Honda CR-V Touring AWD
Sensors probably got blocked by the snow and ice. Did the issue go away?
brudacille
Brent
York, PA
2019 Honda Civic Si, 2019 Type R
Any update? Experiencing this now and can't even use my parking brake to go in the house
Craiglane772
Craiglane772
Craig
Not sure if I’m doing this reply right (new too this) but yes it always goes away after 15 mins of driving or so but it’s not fun doing so as I have no traction control while doing the drive to reset the lights but yes it seems to go away after some time driving
Craiglane772
Craiglane772
Craig
Yea issue went away and hasn’t came back yet....that is till we get more snow lol
Craiglane772
Craiglane772
Craig
Yea the e-brake button sucks but if you turn off traction control you can still have a good time in reverse it seems that even in 5+ inches of snow I still couldn’t loose enough grip to fully do anything cool in drive though
