Dash Rattle
  1. Nighthawk
    Nighthawk Senior Member
    Mar 26, 2017
    105
    Midwest
    2017 Civic Si Sedan
    My 2017 Si sedan has been making this rattle for awhile now. Has anyone else heard something similar to this noise?
    It seems to be coming the passenger side close to the fire wall. I’ve been under the car with the aluminum panel and plastic panel removed, the noise is definitely from inside. If not it’s on the other side of the firewall.
    In the video I have the glove box removed and a plastic panel removed.
    Let me know what you guys think.
  2. mvela
    mvela Senior Member
    Sep 13, 2018
    1,016
    483
    Orange, Tx
    Is it making that noise while you are driving or parked?
  3. OP
    Nighthawk
    Mar 26, 2017
    105
    Midwest
    2017 Civic Si Sedan
    It usually does it while driving. I’m thinking while under throttle the engine vibrates enough to make the noise. Sometimes after driving for awhile at idle it will make the noise but louder. Kind of like if something is stuck inside the blower motor going around and around. Or like when they used to put a card on the wheels of your bike. My guess it’s at piece of plastic that expands with the cold and heat.
  4. mvela
    mvela Senior Member
    Sep 13, 2018
    1,016
    483
    Orange, Tx
    Oh ok. So it only happens with your A/C running?
  5. OP
    Nighthawk
    Mar 26, 2017
    105
    Midwest
    2017 Civic Si Sedan
    Having the fan motor running seems to make it louder. But mainly it’s while the gas pedal is being pressed. At lower RPMs.
  6. mvela
    mvela Senior Member
    Sep 13, 2018
    1,016
    483
    Orange, Tx
    That’s a weird one. Sounds like you might just need to take it in and let your warranty take care of it. That’s what I would do. Let us know what you find.
  7. wintercast
    wintercast Senior Member
    Apr 15, 2019
    Churchville, MD
    Ridgeline
  8. OP
    Nighthawk
    Mar 26, 2017
    105
    Midwest
    2017 Civic Si Sedan
  9. wintercast
    Apr 15, 2019
    Churchville, MD
    Ridgeline
    yeah it can be difficult to find rattles, more so if you really need a second set of hands in the car as it is driven!
    i cannot stand any rattles - i cannot even stand it if a bottle or something is rolling around on the floor.
  10. SDAlexander8
    SDAlexander8 Senior Member
    Jul 11, 2019
    647
    435
    Occupation:
    Environmental
    Indianapolis, IN
    Steve
    2017 Civic Si Coupe
    I have noticed this rattle as well under acceleration and after jiggling a bunch of thinGs under the hood I have noticed that the Windshield washer fluid sprayer nozzles on the underside of the hood are loose.
    I havent messed around with them other than jiggling them around a bit to see if they had any play, but there has to be a way to tighten these or secure them better.
    There is also that clip holding the fuel line along the firewall that seems loose.
  11. OP
    Nighthawk
    Mar 26, 2017
    105
    Midwest
    2017 Civic Si Sedan
    Thanks for the suggestion I’m going to try to see if that’s the cause of my rattle problem.
  12. Memogiyi
    Memogiyi Senior Member
    Aug 18, 2019
    51
    Mission Hills
    Guillermo
    2017 Honda Civic Si
    I had the same issue after an oil change! I would notice the rattle when I would gas it above 2500rpm. It turned out to be one of my HID ballast was lose and hitting against the fender. As soon as I adjusted it and made sure it no longer moved, the rattle went away. I hope that helps!
  13. Siiick
    Siiick Senior Member
    Oct 28, 2019
    248
    447
    Texas
    2020 Civic Si, 2019 Corvette Z06, 2017 Fiesta ST
    Every car I have ever owned has always had some kind of annoying rattle in the interior. I just crank up the stereo louder :headbang:
  14. evilearn
    evilearn New Member
    Nov 29, 2017
    Boston
    2017 civic si
    I had a similar rattle. It sounded like it was coming from the driver side air vent. I told the dealer when I was getting it serviced and they fixed it. Unfortunately now I hear it from the passenger air vent as well.
  15. ebhaynz
    ebhaynz Senior Member
    Mar 18, 2017
    310
    162
    Lost Wages, Nevada
    Civic Si 2017
    Here's how you might be able to fix those rattles. It worked miracles for my 17 Si gl.
