moistener
- Jul 21, 2017
- 11
- 146
- 382
- Canada
- 2017 Honda Civic Touring
- Vehicle Showcase
I purchased a set of D2 Racing RS coilovers from @procivic and had them installed. It's been about a couple weeks and I wanted to give a quick review on them so far. I went for a mild drop (about an inch lower or 2 finger gap between the tire and fender) as it'll be winter soon. Keep in mind, what you see in the photos is the max height for the rear coilovers.
I've had Tein's on my previous vehicle and like these, handling and stability is much improved. However, the ride quality has taken a bit of a hit. Bumps and dips on the road are definitely noticeable and you'll definitely have to be careful driving on poorly paved roads. I'm currently playing around with the damper settings and to be honest, I haven't noticed much of a difference between the settings of 1 to 16 (clicks from 'soft'). The 36-way dampening system seems like it would offer a lot of adjustability but this may be more of a gimmick and any difference may be more psychological. I would expect more expensive brands like Ohlins to have a more distinct feel between the damper settings.
Time will tell on how they hold up. Rough roads (sharp bumps, dips, and potholes) can be pretty jarring even at the softest dampening settings and the mild drop that I currently have. In the end, I like how my vehicle sits and will update this thread on how these coilovers age. Thanks for reading!
EDIT: Since this post I've switched my setup to Eibach Pro-Kit springs and I'm thrilled with this setup for the D2 Racing RS coilovers. In short, the coilovers were a bit too aggressive for me and the roads where I live don't take too kindly to this setup. You can check my post history on a more detailed reason why I made the switch.
