D2 Lowering Springs with Aftermarket Wheels
ericscott21
Eric
2017 Civic SI coupe
Hey guys, so i am planning on getting Konig Oversteer 18x8, +35 offset and using stock tires due to my insufficient funds as of now. Does anyone know about it i would possibly rub on the D2 lowering springs due to my wheels being pushed out 15mm from oem? Thank you guys in advance for the help!!
iamrealskinny
Mark
Lowell, MA
instagram.com
2017 Civic Si
You won't rub. I have some AV-06s 18x8.5 +35 and I don't rub.
iamrealskinny
Mark
Lowell, MA
instagram.com
2017 Civic Si
jgreen16
Cleveland, OH
2020 Civic EX Hatch, 1990 Chevrolet C1500
Had the exact same spec Oversteers on my car with Eibach Sportline lowering springs, and it wasn't even close to rubbing. The D2's may lower it just a bit more, but you should be fine.
tgastte
tristan
socal
2018 civic si
I'm running D2 springs, both my Wedssprort and Rays gramlight 18x8 et 36 on stock tires, no rubbing or scraping 4 people and bags to Vegas still no problem, I don't think 1mm makes a difference in your offset of 35.
Honda Civic 10th gen D2 Lowering Springs with Aftermarket Wheels 7ED71F8D-FE7D-4656-8FC0-D770184FAC3C
Honda Civic 10th gen D2 Lowering Springs with Aftermarket Wheels 05FCF91D-98AB-4033-A2F6-AD4270223CCA
Honda Civic 10th gen D2 Lowering Springs with Aftermarket Wheels B8CA181C-67CA-410C-9D02-1E508BC75EF8
Honda Civic 10th gen D2 Lowering Springs with Aftermarket Wheels D1334364-9BF0-4AB7-9CF3-F5696E91E250
Honda Civic 10th gen D2 Lowering Springs with Aftermarket Wheels FEBCDF0E-22B0-4E0A-BBEC-B032709237BF
Honda Civic 10th gen D2 Lowering Springs with Aftermarket Wheels 668272ED-3F92-44B7-8116-25851E988881
Honda Civic 10th gen D2 Lowering Springs with Aftermarket Wheels D0D0FC2F-41CD-4715-AEC0-0402C90ABC15
Honda Civic 10th gen D2 Lowering Springs with Aftermarket Wheels B251917F-AD92-4880-98F7-CD700AD9A022
jgreen16
Cleveland, OH
Nice looking wheel setups. I especially like those Wedssports.
ericscott21
ericscott21
Eric
2017 Civic SI coupe
awesome thanks for your help!
Triple_peaz
Brother Taresa
Brandon
Louisiana
2019 Honda civic si sedan, 2016 Honda pilot
Did you take off your mud guards because of the drop or just because? Looks nice either or
tgastte
tristan
socal
2018 civic si
I never had a mud guards from day one...it's probably just how my car sit..
Toronto, ON
2018 Honda Civic Si Coupe
I'm looking at the same wheel specs too. Do you think I'll rub if I go 245/40, lowered on Eibach sportlines?
Pekingduck
Albert
Southern California
Na
I am running Enkei 18x8.5 +38, with stock tires, eibach sportline and I rub a little bit on certain style street gutter intersection with different grade of streets.
Honda Civic 10th gen D2 Lowering Springs with Aftermarket Wheels E556777B-6BE1-4FE4-8B14-50EA10EED982_zpsogcjp9am
Nickuh
Nick
Illinois
2018 civic si
has anyone dropped their civic on 19 inch wheels or more specifically the hfp rims?
arpypat
Civic
The 19" HFP wheels have the same OE spec offset and similar rolling diameter since the tire has a smaller sidewall. From what I've read, you'll need a rear camber kit with pretty much any spring set if you want OE spec rear alignment.
