CVT failure: Details inside
  1. Papayank
    Papayank Senior Member
    Jul 12, 2019
    339
    50
    Kevin
    Honda civic
    Hmmm I ask because I noticed when flooring.....my car kinda jerk a little and go faster for example the rpm goes to 3k and then when it goes to 4k rpm its like a gear changing but it goes faster I don't know how to explain it
  2. OP
    Coupe-R
    Coupe-R Senior Member
    Mar 22, 2018
    76
    35
    '18 Civic EX-T Coupe CVT
    I see, yeah that is definitely not what I felt. That sounds like the regular simulated shifts the CVTs do.
    Papayank thanked this.
  3. xjoshuax89
    xjoshuax89 Senior Member
    Mar 26, 2016
    882
    538
    Maryland
    Josh
    Cvt. Tuned at IMW by Derek Robinson and I've been using the full VSA off.
    Not sure if I am reading that chart right but close to max 390 wtq?
    Seems like issue of too much tq down low with waaay too much boost.
  4. gtman
    gtman Senior Member
    Oct 27, 2015
    5,797
    6,139
    Occupation:
    CivicX addict
    U S of A
    2017 Cosmic Blue Civic EX-L
    That dyno plot was from his first tune I think. Coupe-R sent me his current tune settings and everything looked kind of "conservative", considering. Early spool on with factory part throttle turbo response and factory boost ramp. 24 psi above 5000 rpm only. Final boost at 24 as well.
  5. xjoshuax89
    Mar 26, 2016
    882
    538
    Maryland
    Josh
    Question is how much boost down low. And I dont think settings will show really how much tq is being generated down low. If its 20psi in 1st and 2nd "gear" we have our answer. Too much too early.
  6. OP
    Coupe-R
    Mar 22, 2018
    76
    35
    When I got that dyno plot, they said ignore the torque numbers as they weren’t being read right by the dyno due to being a CVT. They said at that time it was probably around 225-235lb-ft for torque.
  7. gtman
    gtman Senior Member
    Oct 27, 2015
    5,797
    6,139
    Occupation:
    CivicX addict
    U S of A
    #22 gtman, Sep 2, 2019
    His tuner set BBG to 15 psi in 1st.
    Here are the boost targets I saw 2500-6500 rpm:
    2500 - 16
    2750 - 18
    3000 - 20
    3500 - 22
    4000 - 22
    4500 - 22
    5000 - 22
    5500 - 24
    6000 - 24
    6500 - 24
    Coupe-R thanked this.
  8. OP
    Coupe-R
    Mar 22, 2018
    76
    35
    As @gtman said, I sent him my tune file. I don’t have a dyno plot from my second tune as his dyno said I only made 160hp and 160lb-ft, he couldn’t get it to read the CVT right so I didn’t bother getting a printout of those dismal and obviously wrong values. My 1st gear BBG caps at 15psi, the rest are 21psi for “gears” 2-5. I’ve driven cars with higher power and torque than these Civic 1.5s make, I like to think my butt dyno is pretty good. Definitely in the 200-220hp range, and torque feels somewhere in the 220-240 range.
  9. xjoshuax89
    Mar 26, 2016
    882
    538
    Maryland
    Josh
    Hmmm that is certainly very interesting. Thanks for sharing!
  10. Papayank
    Jul 12, 2019
    339
    50
    Kevin
    Honda civic
    How long you have tune for?
  11. OP
    Coupe-R
    Mar 22, 2018
    76
    35
    About 1 year.
  12. mikey003
    mikey003 Senior Member
    Jul 28, 2019
    60
    35
    2019 Civic
    no they are not,
    your just not hearing about them all,
  13. dallasjhawk
    dallasjhawk Senior Member
    Oct 3, 2016
    3,910
    3,805
    Arlington, TX
    2016 Civic EX-T, 2004 Acura TSX
    Yeah because internet troll knows everything, get lost
    CVTsport18 and theblackdogman thanked this.
  14. 250GTCalifornia
    250GTCalifornia Senior Member
    May 5, 2017
    217
    57
    Civic
    This is how detailed and forthcoming every one of these "blew my engine" posts should be. Thank you, Coupe-R.
    CVTsport18, ddood, Coupe-R and 1 other person thanked this.
  15. julianzh
    julianzh Senior Member
    Apr 1, 2016
    355
    118
    Quincy
    2016 Civic EX-t
    Thanks for the thread. Very interesting to read until the tune hater appeared.
    CVTsport18, dallasjhawk, ddood and 3 others thanked this.
