Hallsie84
Hello. I have an 18 honda civic hatchback sport. New here and dont usually post unless there is not alot of info already out there. For new civics and fiberglass boxes there is not so here ya go. I kept factory head unit. 5 channel pioneer amp. I highly recommend. Fosgates in door front and back. Also great. Audio control line converter. Works well. Also have the acr1 remote level custom intalled beside the shifter. Highly recomend also. Started with a planet audio sub. Did not like it. Ordered a skar audio 8 inch sub for the first time. Well built. Good price. Love it. As far as the install....removed jack and plastic that held it and cut off the piece of metal frame that stuck out. Painted the cut. Pics explain the rest. Took the foam that holds the tools in the spare tire and cut it to hold the jack. Inverted cone that held spare tire and cut the bolt shorter to fit smaller length. Taped other side and used the tape template on a piece of painted mdf to find shape of other side. Hot glued mdf on to the carpet. Then amp on it. Nice and sturdy. No complaints. Im sure im missing something and if there is interest ill answer any questions or be of any help i can. Just wanted to help those with similar ideas or interest. Thanks
