Type-JZ
- May 1, 2017
- 11
- 588
- 311
- SoCal
- '13 Lexus GS350, B13 Sentra SE-R, '93 Camry, '07 TSX, '13 Odyssey
pretty much verbatim. Look at them and compare. the Beatrush is a 32mm shaft, so it looks beefier/stronger. Anyways, i ended up getting the Cusco bars since one of the locals had it in stock.Both beatrush and Cusco have their approach on how they want to stiffen the FK8 platform. I prefer Cusco, As to Beatrush looking beefier/stronger? What are you referring too?
In regards to doubling a cusco center brace and spoon stiff plate I would just choose one or the other. I don't think both will fit at the same time. Cusco allows your to reuse your existing bolts. As for the Spoon's it will come with new longer bolts to install their stiff plate.
I can also attest the OEM plastic under tray fits without any issues. In fact, if you're just doing the front bar only for whatever reason, you don't even have to remove the entire under tray. Remove the alum piece and you can get enough clips out to pull down and slide the bar thru. But, you have to remove the plastic for the center bar. I tried, but by the time i took off the clips, i had 4 more to go to remove the whole thing, so i just removed it. The back, you don't have to remove exhaust. I just slid the bar thru. I didn't use any support for the sub frame either. it doesn't move. It's got enough bolts attached to it and is fixated.
