PowerPerLiter
Specific Output
Is there a hierarchy or can someone elaborate for me the strategy for the ecu to adjust the boost level to maintain targets. Example: does the bov vent first after the wastegate gets adjusted and then timing? Does the car adjust intake or exhaust valve overlap during certain conditions to "bleed off cylinder pressure". Is there a good technical response or do we know fully? From my understanding all the electronic control of the wastegate/recirc valve/ throttle blade are all real time and adjusts incrementally at a fairly constant rate to stay at certain boost targets.
In any of the aftermarket tunes is valve overlap manipulated to induce quicker spool time or increase top end?
Does the honda factory calibrations use valve overlap to help keep the intake valves clean as apart of their strategy to combat carbon buildup at light cruise (say during emissions system checking at low load)? Do the stage tunes change this?
Thank you in advance.
