CTR Rev Matching and Emissions Issues w/Check Engine light.
  1. CSIG1001
    CSIG1001 Senior Member
    Jul 1, 2017
    289
    75
    COS
    2004 V6 6 SPEED COUPE ACCORD
    is honda replacing the harness with a new version? Just curious since i will be in a 2018 model late next year
  2. tacthecat
    tacthecat Senior Member
    Feb 9, 2016
    1,136
    418
    Cheshire, MA
    '12 Civic Si Sedan, '98 Civic EX Coupe 5MT
    The harness is just fine - the assembly method/QA needs adjustment. Worse case is a - (dash) number update if they modify the assembly/build method.
  3. CSIG1001
    Jul 1, 2017
    289
    75
    COS
    i would beg to differ . If there is a connection issue the harness should be redesigned to accommodate a tighter connection
  4. tacthecat
    Feb 9, 2016
    1,136
    418
    Cheshire, MA
    Differ you may but the problem is implementation/assembly not design. You don't do a redesign for a workmanship/tool issue - you establish a better QA or tool check to fix the process not the design.
  5. jmayo1056
    jmayo1056 Senior Member
    Jul 9, 2017
    81
    93
    Salinas CA
    Jeremy
    2017 Civic Type R PMM #1056
    Mine just went off yesterday. Badge 1056 vin 201150. About 4400 miles on it. Just made a road trip to Tucson from Northern California. Thankfully it didn't do it while on the trip. Once the dealer lets me know what the problem is I'll update.
  6. jmayo1056
    Jul 9, 2017
    81
    93
    Salinas CA
    Jeremy
    Can we try and get a head count of who has had this problem.
    1. Jmayo1056
    2.
    3.
    4.
    5.
    6.
    7.
    8.
    9.
    10.
  7. vanovem1
    vanovem1 Senior Member
    Jun 23, 2017
    98
    125
    Occupation:
    Software Engineer
    Pasadena, CA
    2017 Honda Civic Type R, 2007 Honda Civic Si
    1. Jmayo1056
    2. Vanovem1
    3.
    4.
    5.
    6.
    7.
    8.
    9.
    10.
  8. ayau
    ayau Senior Member
    Aug 14, 2016
    1,170
    962
    Subaru
    Would a possible fix be to just cuz the zip tie or re-zip tie the wires and give it more slack?
    Is the wire disengaging from the plug? If the wire gets disengaged, can't you simply push the wire back into the plug instead of having to solder it?
  9. ayau
    ayau Senior Member
    Aug 14, 2016
    1,170
    962
    Subaru
    Have you figured out the exact part number for the replacement harness? Is it a main harness or a sub-harness?
    LoveToDrive thanked this.
  10. RP2000R
    RP2000R Senior Member
    Apr 13, 2017
    586
    380
    WA
    Civic Type R #1008, 15 Lexus IS350 RWD, 18 civic SI, 16 Tundra Pro CM
    I want to prevent it from happening..
    I'll do tug test and look at cutting the zip tie to provide less stress on the harness.
    I don't want the car taken apart/new harness and if it happens to me I'll have it soldered and documented.
    Ruckus thanked this.
  11. Travis
    Travis Senior Member
    Jul 5, 2017
    188
    103
    Cincinnati, Ohio
    Travis
    2017 Honda Civic Type-R
    So my errors went away yesterday but I still wanted to have it checked out. Honda service looked at it and couldn't find an issue. They had it for 2 hours. Once I left about 20 minutes into my drive to work the errors returned! Does anyone have a contact number for the service tech's that have already fixed this issue so I can tell the guys at my honda dealership to call them and get it handled
    zroger73 thanked this.
  12. vanovem1
    Jun 23, 2017
    98
    125
    Occupation:
    Software Engineer
    Pasadena, CA
    Don't have a number off hand, but ask your tech to call Bel Air Honda. The master tech there is the one who fixed mine.
    Travis thanked this.
  13. RP2000R
    Apr 13, 2017
    586
    380
    WA
    Show them this thread and have them call the tech line
  14. Travis
    Jul 5, 2017
    188
    103
    Cincinnati, Ohio
    Travis
    1. Jmayo1056
    2. Vanovem1
    3.Travis
    4.
    5.
    6.
    7.
    8.
    9.
    10.
  15. Ruckus
    Ruckus Senior Member
    Jun 9, 2017
    324
    388
    Wisconsin
    2017 Civic Type R. 2012 Honda Ruckus. 2001 civic sedan. 2012 accord sedan.
    the post doesn't have any part numbers listed some im unsure if the harness has already been "updated" although i doubt it has been. there are 3 engine harnesses located under the hood to my knowledge although im not sure which harness this particular connector is on. haven't had the issue yet myself so i haven't spent much time looking into it. personally i just cut the zip tie because it looked like it was pulling the wires too tight and gave the wires a tug to make sure, for now at least they were okay
