CTR Rev Matching and Emissions Issues w/Check Engine light.
  1. zroger73
    zroger73 Senior Member
    Apr 15, 2017
    2,329
    4,321
    United States
    2019 Ridgeline RTL-E, 2019 MX-5 Miata GT-S
    Yes. Primarily, the faulty connection causes an emissions-related error which indirectly affects the rev-matching feature. It's not unusual to see multiple errors appear as the result of a single failure for subsystems that rely on information from the same sensor.
    For example, if a wheel speed sensor signal is lost on a model with Honda Sensing, the dash will light up like a Christmas tree with error messages from every system that relies on wheel speed data (ABS, VSA, traction control, automatic braking, adaptive cruise control, lane-keeping assist, lane departure warning, hill-hold assist, etc.).
  2. ayau
    ayau Senior Member
    Aug 14, 2016
    1,173
    963
    Subaru
    How intrusive is the wiring harness replacement? Does a lot have to be removed in order to replace the harness?
    Might be worth holding off on getting this car until the harness is replaced at the assembly line. If there's a service bulletin, it should indicate the affected VIN range.
  3. mikec27
    mikec27 Member
    Jun 10, 2017
    63
    Maryland
    2009 S2000, 2017 CTR
    I don't believe the rev match has anything to do with this failure, it just seems to get disabled when a check engine light is on.
  4. tacthecat
    tacthecat Senior Member
    Feb 9, 2016
    1,173
    437
    Cheshire, MA
    '12 Civic Si Sedan, '98 Civic EX Coupe 5MT
    Just the opposite - the Check Engine light is a summary of many inputs one of which is the Rev Match sensor input.
    As the ECU is looking for the Rev Match, along with VBS, mis-fire, etc sensors as part of its start-up check, it's likely the error will occur, if you have the problem, even with the function turned off.
  5. zroger73
    Apr 15, 2017
    2,329
    4,321
    United States
    There's no such thing as a "rev match sensor". Rev matching is strictly a software feature that uses data from existing sensors that provide engine RPM, vehicle speed, and gear position. As long as the ECU knows what gear the transmission is going into using the gear position sensor and how fast the vehicle is going using the vehicle speed sensor, it can modulate the engine speed using the electronic throttle control and engine speed from the crankshaft position sensor for closed loop feedback control.
    Solis#1730 and vanovem1 thanked this.
  6. tacthecat
    Feb 9, 2016
    1,173
    437
    Cheshire, MA
    Agreed - the loose/intermittent connection is part of the circuit(s) utilized for many things one of which is to do the Rev Match function. From what I've seen of this issue, the predominant, but not the only, error indicated is the Rev Match error. There is no such unique item as a "Rev Match Sensor", just as there is no such item as an Emissions Sensor. The ECU reads all available inputs and if one or more is out of limits, including missing, it will trigger an alert, unique if appropriate, store a code, take appropriate action, set the "Malfunction" icon if emissions related, and the "System Message" Icon. Apparently the secondary O2 sensor line is also utilized in some manner as that is the circuit reported as the culprit, or there's a software error.
  7. Travis
    Travis Senior Member
    Jul 5, 2017
    188
    103
    Cincinnati, Ohio
    Travis
    2017 Honda Civic Type-R
    Just Fell victim to the emissions and rev match problem today. 1166 Miles. Badge #1086. Its Sunday so they are closed. Guess I have to wait until tomorrow to take it in. Is it safe to drive for say... 80 miles?
  8. jdmorangefever
    jdmorangefever Senior Member
    May 22, 2017
    402
    278
    Nevada
    93 eg, 17 type r, 16 crv
    As long as the check engine light is not flashing you should be ok
  9. Travis
    Jul 5, 2017
    188
    103
    Cincinnati, Ohio
    Travis
    How long didn't take to replace?
  10. vanovem1
    vanovem1 Senior Member
    Jun 23, 2017
    98
    125
    Occupation:
    Software Engineer
    Pasadena, CA
    2017 Honda Civic Type R, 2007 Honda Civic Si
    Once the part actually came in, the master tech had it done the following afternoon
    Ruckus and Travis thanked this.
  11. ayau
    ayau Senior Member
    Aug 14, 2016
    1,173
    963
    Subaru
    Do you mind posting the warranty work paperwork? Just curious what's involved in the repair.
    Do they have to replace the entire engine harness or just the plug?
  12. vanovem1
    Jun 23, 2017
    98
    125
    Occupation:
    Software Engineer
    Pasadena, CA
    The dealer kept the paperwork for me...they had to replace the entire engine harness. This is what Honda is recommending they do so that they can inspect the harness to prevent the issue at the source.
    Ruckus thanked this.
  13. ayau
    ayau Senior Member
    Aug 14, 2016
    1,173
    963
    Subaru
    If they're replacing it with the same wiring harness, then the issue is going to pop up again. I wonder if they're already changed the wire itself at the factory?
    Not sure if you know the part number of that wiring harness or not.
  14. Chee_hu
    Chee_hu Senior Member
    Feb 21, 2017
    904
    702
    Elk Grove, California
    Sherwin
    #611 Rallye Red CTR | 1998 Civic EX | 2007 Honda Fit Sport
    Would it be crazy to bring the car in and have the harness replaced before getting the code?
  15. tacthecat
    Feb 9, 2016
    1,173
    437
    Cheshire, MA
    Better yet, take it to your dealer and let them do the TT (Tug Test) and if the wires don't come out you can wait (forever).
    Chee_hu thanked this.
