CTR Rev Matching and Emissions Issues w/Check Engine light.
  1. TypeCrane
    TypeCrane Member
    Jun 2, 2017
    Occupation:
    Tower Crane Operator
    Boston Strong
    G Money
    2017 Civic Type R Touring
    Stopped by the dealer this morning, the tech pulled code p0030 and stated i may need to swap out my ECU, which is worth $2k. I was told to come back thur, since tech support isn't available until then. I'm going to try out a different dealer tomorrow.
    All-Knowing thanked this.
  2. RP2000R
    RP2000R Senior Member
    Apr 13, 2017
    582
    377
    WA
    Civic Type R #1008, 15 Lexus IS350 RWD, 18 civic SI, 16 Tundra Pro CM
    Is the wire the plug for the secondary O2? The pictures confused me.,
    Lol
  3. All-Knowing
    All-Knowing Senior Member
    Feb 3, 2016
    648
    1,159
    Hondaville
    NSX
    There's pics of TWO different problems. One is the 02 coupler and the other is the blow off valve solenoid wiring.
  4. Cpt-GargameL
    Cpt-GargameL Senior Member
    Jun 14, 2017
    71
    107
    South FL
    2017 CW Type-R
    When I had this issue, My mechanic just soldered the wires so they wouldn't disengage with the harness. No need to order anything. I watched them troubleshoot until they were able to resolve the issue, I was in and out of Honda in 3 hours.
    Hondanatic and Ruckus thanked this.
  5. OP
    CivicTypeRMan
    CivicTypeRMan Senior Member
    May 24, 2017
    151
    110
    TN
    E350/Soon to be Type R
    Yes, O2 sensor plug
  6. OP
    CivicTypeRMan
    May 24, 2017
    151
    110
    TN
    That happened to me too. However, Honda sent the dealership a new O2 sensor because they said it should be replaced and not a temporary fix.
  7. OP
    CivicTypeRMan
    May 24, 2017
    151
    110
    TN
    Badge#1066
  8. Cpt-GargameL
    Jun 14, 2017
    71
    107
    South FL
    2017 CW Type-R
    So far so good still. I'll report back if the issue arises again and get the O2 sensor replaced.
    CivicTypeRMan thanked this.
  9. fk8_#798
    fk8_#798 Senior Member
    Jun 27, 2017
    177
    Delaware
    pablo
    2015 civic is fully built engine and tranny supercharged e85 , 2017 civic touring 1.5t sedan., 2017 civic type r hatchback 2.0 turbocharged
    #84 fk8_#798, Jul 8, 2017
    these things happen........and also those comparing the fk2 to the fk8 saying same engine why is the fk8 having issues.....the fk2 was not built as strong as the fk8 which a lot of technology went into. water cooled manifold , oil cooler and tranny cooler forged rods and crank the fk2 didn't , also sodium filled valves so forth and so on....so u cant say they are the same engine completely.......this is a new engine build and these things will happen and will be corrected ...
    JJAY8175 and pdiizeru thanked this.
  10. tacthecat
    tacthecat Senior Member
    Feb 9, 2016
    1,134
    418
    Cheshire, MA
    '12 Civic Si Sedan, '98 Civic EX Coupe 5MT
    VIN defines production sequence better than Badge Number.
  11. House of hondas
    House of hondas New Member
    Jul 8, 2017
    Ian
    2017 civic type r, 12 Honda Accord v6, 02 accord se, 00 civic si, 97 civic hatchback, 88 crx si, 06 accord v6
    I've had mine for a week I have 399miles on it and the check engine light came on along with the Rev matching error it drives the same except no Rev matching. Took it back to the dealer yeaterday still waiting for them to diagnose it.
  12. BigLT42
    BigLT42 PROUD OWNER OF CTR #1762
    Jul 5, 2017
    KNOXVILLE TN
    LT
    2017 TYPE R 2017 yamaha r6
    Happened to mine #1762 tech had to repin the connector and sent his fix into honda. It was a fairly easy repair and now she is just fine
  13. zroger73
    zroger73 Senior Member
    Apr 15, 2017
    2,246
    4,188
    United States
    2019 Ridgeline RTL-E
    Honda need to find a new supplier for their wiring harnesses. Last year when the all-new 2017 Ridgeline was introduced, the first few months of production had a wiring harness running from the cab to the bed that had a crimp splice placed in the wrong location by the supplier. Water would drop onto this splice then wick down the wire all down to a connector then into another connector on the rear differential. In some cases, the rear differential and entire cab/bed wiring harness had to be replaced which was a major job. The proactive solution was to cut and disable a wire then run a new one alongside it - kind of a hack-job solution, but it was better than risking additional damage and ending up with "extra parts" resulting from major disassembly of the vehicle.
  14. Chee_hu
    Chee_hu Senior Member
    Feb 21, 2017
    877
    683
    Elk Grove, California
    Sherwin
    #611 Rallye Red CTR | 1998 Civic EX | 2007 Honda Fit Sport
    Would it make sense to just take the car in and have them check/replace the faulty part, or am I just being paranoid? I know it only affects and inactivates the rev matching feature, but I've gotten to love and used to it :rofl:
  15. CTR1633FK2
    CTR1633FK2 Senior Member
    Apr 25, 2017
    571
    392
    Netherlands
    Civic Type R Fk2 base
    Just fixing the connector is the safest solution. IMO much better than replacing the whole harnass. You can check it yourself by pulling the connector out.
    Ruckus and Chee_hu thanked this.
