Coolant in Cold Climates
  1. NightStalker
    NightStalker Member
    Oct 17, 2017
    Yellowknife, NWT
    2017 Civic SI
    So I must be horrible at searching or the question was never asked but here it goes.
    I live in Northern Canada, its going to dip below -42C (-43.6F For my American brothers) and hover around those temperatures for the foreseeable future.
    I own a 2017 Civic SI, I noticed two things. One, the coolant level is wayyyy low (I guess the dealership didn't fill it like they said they would when it was in for warranty work) and secondly the manual states the mix is good up to about -35C/F cant remember which.
    My question is can you mix the Type 2 fluid safely with something else? And does Honda sell the OEM coolant without a pre-mix? I'm not sure how else to throw in a higher coolant concentration without flushing the whole system with a non-oem brand coolant and mixing it with water myself.
  2. latole
    latole Civic Lx 2018 Manual , Civic LX 2016 Manual
    Apr 13, 2017
    1,965
    439
    Vaudreuil,Quebec ,Canada
    " And does Honda sell the OEM coolant without a pre-mix?"
    - NightStalker
    Phone call to your Honda Dealer in your cold area, he must know what you need.
    _______________________________________________________
    The concentration of antifreeze in the coolant also needs to be checked prior to the onset of cold weather. A 50/50 mixture of antifreeze and water is recommended and will protect against freezing down to -34 degrees F and boil over protection to 263 degrees F.
    For maximum protection, up to a 70% mixture of antifreeze can be used for freezing protection to -84 degrees F.
    CAUTION: Do not use more than 70% antifreeze, and never run straight water in the cooling system because it offers no corrosion, freezing or boil over protection.
    https://www.hondaoakland.com/service/service-tips.htm
    __________________
    Never mix coolant :
    https://tap.fremontmotors.com/trusted-auto-professionals/mix-different-types-coolant
  3. OP
    NightStalker
    NightStalker Member
    Oct 17, 2017
    Yellowknife, NWT
    2017 Civic SI
    There are no Honda dealers around unfortunately.
  4. latole
    Apr 13, 2017
    1,965
    439
    Where are you going for car maintenance ?
    Wait for some more answer, all forum member are at work now .
  5. Gruber
    Gruber Senior Member
    Jan 27, 2018
    1,247
    700
    TN
    Mark
  6. OP
    NightStalker
    NightStalker Member
    Oct 17, 2017
    Yellowknife, NWT
    2017 Civic SI
    Unfortunately there's really only one shop I can trust up here, they have yet to disappoint me.
  7. OP
    NightStalker
    NightStalker Member
    Oct 17, 2017
    Yellowknife, NWT
    2017 Civic SI
    You think maybe it would be good to flush the system first?
    Also the shop I went to mentioned they tested the coolant and it showed a freezing point up to -43 or so. I called my dealer down south I bought the car from and they usually only fill the 50/50 mix in the cars they sell soooo this has been interesting indeed.
  8. latole
    Apr 13, 2017
    1,965
    439
    Did you have this tool ? It is cheap. You'll see what is the freezing point.
    Youp shop test it at -43 , you don't truss them ?
    Test it with a “coolant hydrometer” available at any auto parts store. This inexpensive device measures the specific gravity of the coolant. It does not, however, tell you anything of the corrosion protection capabilities remaining in the coolant. Simply insert the tip of the hydrometer into the antifreeze and pull some into the chamber, enough that the float lifts free. The reading tells you the freeze protection.
    https://www.cartechbooks.com/techtips/antifreeze
  9. latole
    Apr 13, 2017
    1,965
    439
    In your country, what other car driver do with their coolant ?
  10. fitter_here
    fitter_here Senior Member
    Apr 2, 2016
    395
    147
    Ste-Anne-des-Plaines, Quebec, Canada
    Civic LX 2016 Sedan
    It wouldn't make any damage if you add a cup or so of coolant (coolant for all cars). I used to live in Cold Lake (north of Alberta) and I mixed about 60/40 for coolant. We had about the same temperature than Yellowknife.
    NightStalker thanked this.
  11. latole
    Apr 13, 2017
    1,965
    439
    Safer to buy a coolant made for Honda car
  12. Gruber
    Jan 27, 2018
    1,247
    700
    TN
    Mark
    I don't believe it's possible that the Honda coolant used since 2001 or so on all their cars has anything special about it. It is generic. Any major brand coolant of the exact same type should be just fine. Honda doesn't use any special metals or materials in all their cars for decades that's different from all the other engines that use the same type of coolant.
    So I would not have any problem mixing the above coolant with Honda Type 2 based on a careful calculation based on volumes etc. if you actually need lower freezing temp. But if you add too much ethylene glycol the freezing temperature will actually rise. Pure ethylene glycol will freeze at about negative 12 C.
    You can test by mixing them in a jar. No cloudiness or solids should appear. Maybe even the label also says you can mix them. Or you can drain, flush, refill for exact composition.
  13. latole
    Apr 13, 2017
    1,965
    439
  14. Gruber
    Jan 27, 2018
    1,247
    700
    TN
    Mark
    #14 Gruber, Jan 15, 2020
    Yes. It's usually much easier to go to Walmart or any auto parts store than to a Honda dealer. Also Honda parts dept. has more limited opening hours. But most important here is that I don't see Honda offering concentrated coolant.
  15. fitter_here
    Apr 2, 2016
    395
    147
    Civic LX 2016 Sedan
    By the way, Yellowknife is in Canada..lol
