gylmar814
Gylmar814
- Gylmar
- Oct 2, 2017
- 31
- 316
- 309
- Miami, FL
- 2017 ABM Civic Si Sedan, 2018 Mazda Cx-5, (RIP) '17 SGP Civic Hatch Ex
Clocking in at almost 15k miles on my Si and never experienced no signs of clutch slipping until now, after reflashing the ecu with the TSP stage 1 Map. I use flashpro so my car automatically uses the 19/24.5 psi tune and I noticed yesterday while driving home from work in sport mode the rpm tach needle was fluctuating up and down at about 3k rpms in 5th and 6th gear just giving partial throttle. I'd say the boost load was approx 19-21psi when I was on throttle. If i gave it a little more throttle , you can see the slipping get worse and skip a couple hundred rpms. Obviously I know this doesnt help anything but wanted to see where my clutch stands.
Seems its showing early signs of clutch slipping. Bummer. I thought this stage 1 tune was clutch friendly and had a BBG set in a way that it wouldn't cause harm to the clutch. I would understand if I was putting the engine under stress and flooring it at a low rpm but given that I was a 3k rpms and partial throttle should this still be happening?
Side note: havent experienced this with the Hondata +9 map and no i dont race the car, dump the clutch, never launched the car, etc. Its my daily and I just use it to drive spirited around the city expressway, etc
The tune runs great by the way, at first I wasn't hitting the target boost pressure tsp claimed and honestly didnt feel no different than the hondata map but after noticing they disabled rev hang I decided to reflash the map but with rev hang enable and the car drives much better. Smooth and I easily see 25-26psi around 3rd and 4th gear.
So anyone else experience clutch slipping after flashing this tune?
