Clutch pedal noise
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
So I upgraded to Eman’s clutch master cylinder and bled the system correctly as there was no more air in the system. Driving the car was fine and there wasn’t any noise till later on I adjusted the 17mm pedal height and rod to lower the freeplay a little like I always did with the stock cmc. The. The noise started happening like an air noise but there’s no air in the system.
PowerPerLiter
Specific Output
Midwest
Reverse your last adjustment and see if it's gone?
LilToTo17
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
LilToTo17
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
Would you still recommend the Eman CMC? Is this a common issue? I'll need to know if I am going to get it myself when Eman finally responds to my DM.
Oh yeah Eman’s cmc isn’t the issue lol I still bang gears and no lockouts or grinds but my shitty fx350 is probably toast because Clutchmasters is just a shit clutch brand for 10th gens. I mean they say it’s ok for their clutches to hit and rub against the tranny lol. I did just finish my etuning with Drob so making a lot more torque because I slip at peak torque which is around 4K rpm. W1 turbo with fbo on shit California 91 pump pushing 26-27psi
2tone
Anthony
Fort Myers, Fl
2017 Civic si. 2006 bmw 325i
How many miles on your fx350? I’m about to hit 35k and plan to swap mine while I currently have the time off from work just to be safe but I don’t think mine is ready to give up yet
BoostedDreams
Heisenburg
South East Florida
2019 Type R, 2006 Mazda 6
My spec does the same thing. More of a squeak. Even with an updated CMC from wilwood. You get use to it
LilToTo17
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
9k lol
glossyprimerX
AZ
2017 Sport Hatch MT Sonic Gray
Is there a thread regarding Eman's CMC upgrade? What does he do to make the CMC better? He is working on the type r clutch kit for me. Do I need to worry about upgrading anything else at the same time.
10GenPearlSi
Old Man
Bob
Houston, Tx
2018 Pearl Si
There are threads. He adapts the CTR CMC so it can be fitted into the 1.5T's. That has a larger fluid capacity so it doesn't require as long a throw to the pedal. It works for faster shifts. Mine is a DD so I kept the stock Si CMC. It works OK for me. Just a little longer throw. I now wish I would have upgraded the rear motor mount and put Amsoil in the transmission when I installed the CTR clutch. Downpipe? PS the CTR clutch may be my favorite mod. I can now lay down all the power my Si has!
LilToTo17
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
His Si cmc and type r cmc are different. He also keeps all the dampeners in them.
joshhjackson2112
Josh
Raleigh, North Carolina
18' SI
Eman told me the upgraded CMC was mainly for the CM guys. Told me it was not necessary for my CTR retrofit. Shows you the kind of guy he is. He could have easily sold me on it for extra sale. Can't wait to get mine installed. Still looking for someone to do it atm.
LilToTo17
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
Your problem is you adjusted the rod. I had the same problem almost as a nasty squeaking sound
Yeah lol and no way to fix it? More oem grease?
_.berr
Bryan
Los Angeles, CA
2019 Civic Si
If i remember correctly sometimes adjusting that 17mm can fuck up the rod. I know when my CMC fucked up after i adjusted it i bought another one because it wasnt the same. I could be wrong maybe its just need to be adjusted more
