PaulME
- Paul
- Nov 15, 2018
- 9
- 79
- 35
- MA
- 2018 civic si coupe, 2017 CRV, 2002 Mercedes E320 wagon, 2001 E320 Wagon, 2002 E320 sedan, 1986 944T, 1972 land Rover
ok not a newbie to scratch repair etc, have a porter cable da and various pads polishes etc.
the question is related to clear coat scratches. Search the web and lots of info on wet sanding out clear coat scratches. Seems to me you wind up removing an awful lot of clear coat to bring the level down even.
Now I have used dr color chop in the past on an 80’s Porsche - worked like a champ. So my belief is it should be possible to fill in clear coat scratches with clear coat then just remove the high spot. Seems like 2 ways to do this either wet sand high spot, or you could come up with a weak thinner and chemically remove the high spot like they do with dr color chip. Seems like dr color chip could make a clear product - which they don’t seem to.
So anyone ever try this type of approach? Anyone ever thin lacquer thinner so it is less aggressive to try to just clean a high spot smear?
Comments? Suggestions? Will probably start experimenting as there is little down side, worst case I clean off all the clear coat I apply - amounts are very small (if I resort to wet sanding - sanding block can de about 1/2 inch.
Thanks
Paul
Thanks
Paul
