Whats a good method for cleaning the cluster that wont leave streaks?
I have some overspray and dust on mine that i cant seem to get off completely
I have used Meguiars mirror shine clear plastic polish on my previous cars to clean the gauge cluster. I have not had the need yet to clean my current car as I have only had for 3 weeks.Whats a good method for cleaning the cluster that wont leave streaks?
Can you link or provide the part # for where I can purchase a replacement transparent plastic part of the gauge cluster? I stupidly sprayed cleaner onto mine while it was a hot surface (car was sitting outside on a hot day) and it left dots on the transparent plastic that can't be wiped away.The Good news is that if you end up scratching the transparent Plastic part of the Gauge cluster, a brand new on is about $15 + shipping.
The actual replacing is not such good news.. getting the cluster out to swap out the front transparent part is quite labor intensive, so if you have your Dealer do it, it will probably cost a fortune .. would be a hard sell to convince the Dealer to do that "Under Warranty" !!
Do it yourself, and its very inexpensive.
Check out part #Can you link or provide the part # for where I can purchase a replacement transparent plastic part of the gauge cluster? I stupidly sprayed cleaner onto mine while it was a hot surface (car was sitting outside on a hot day) and it left dots on the transparent plastic that can't be wiped away.
Also, if you know of any DIYs on how to replace it yourself, please share.
Thanks. Yeah, it's more the removing the whole gauge cluster I'm concerned about. Not quite sure where/how to start. I don't want to break anything either! (clips, etc.)Check out part #
78156-TBC-A01
Make sure it is the right one for your year - model.
Swapping out the lens on the Gauge Cluster is quite easy, but I think you do have to remove the whole Gauge cluster to do so , which is probably quite a bit of work. (I have not done it yet)
Maybe someone else, who has done it on the forum, can help ..Thanks. Yeah, it's more the removing the whole gauge cluster I'm concerned about. Not quite sure where/how to start. I don't want to break anything either! (clips, etc.)
Yeah I've looked around (here and YouTube), haven't seen anything yet..Maybe someone else, who has done it on the forum, can help ..
I doubt if there are any You-Tube videos. it's not something that is done by many
Do you have a picture how it looks like?Whats a good method for cleaning the cluster that wont leave streaks?
Did you replace the gauge cluster?Bump, im looking to try and take the plastic gauge cluster off or replace it
