Cleaning brakes and rims?
rucnok
Scott
2019 Type R CW
New 2019 CTR owner. Forgive if this is a dumb question, but how exactly do you clean the inside of your rims and the rotors and such? What is your technique and products? I've never had a vehicle with this type of wheel. Thanks!
ctrmofo
planet earth
'13 lambo lp550-2, '18 honda ctr cw (r-12321), 14' porsche cayman s, '16 porsche macan s, '13 mini jcw nme stage 1, '15 audi s3 apr stage 2, '15 audi q3, '12 monster 1100 evo, '16 triumph thruxton r, deposited for '19 lambo huracan performante
SBPerformance
Steph
2003 Evo, 2003 350z, 1998 CRV, 2019 Civic Type R
I use CarPro ironX
Tip: Ceramic coating your wheels will make cleaning them MUCH easier, I am able to just wash away brake dust with water but for deep cleaning I remove my wheels and ironx them.
You also don't need to clean your rotors, if you are referring to the caliper, microfiber cloth and hot soapy water is suffice (for this I use CarPro Reset Wash) I have seen chemical reactions on the Brembo paint (paint will discolor to a blotchy light red/pink color) with using aggressive wheel cleaners, so be careful with what you purchase over the counter and use on your wheels/brakes.
FifStreet
Michael
Oswego NY
'18 PMM Civic Type R '07 MR Fit Sport (RIP)
I use Car Guys wheel cleaner and brush with a long handle on it.
Coldpizza
CTR
I’ve used Adams wheel cleaner in conjunction with some agitation (wheel Woolies/detail factory brushes) with much success. Cost does add up as I go through a spray bottle after 4 washes, so I’m looking at some other alternatives. Easy to get (Amazon) and use though.
darrvao777
Partenope
'19 CW CTR, '18 G550
I use Auto Fanatic's Wheel Cleaning Foam
I apply via foam cannon
I spray it away with a pressure washer
Probably better if I agitate it but I'm just too lazy :)
Dragnet
Joe
Huntsville, Alabama
2017 Civic Type R, 2016 Accord Sport
I use some wheel woolies that attach to a drill. It takes the majority of the manual scrubbing out of the picture. When you reach the hard to reach points of the wheels around the brembos just pull your car up a foot or so to expose the areas you couldn't reach before. Then clean as usual.
17CivicTypeR_Brian
York PA USA
I use (and sell!) Americana Global Release. It's very similar to IronX but at a better cost point. It works very very well!
However, I also have ceramic coated wheels so I mostly just hit them with the 40° power washer tip (25° works better probably) at close range and just blast it off. It works for getting it 'pretty good' but if you want truly clean - Release and physical agitation.
ctrmofo
planet earth
as some mentioned, best to ceramic coat your wheels. i use all gtechniq products on all my cars for last 6 years and use the c5 wheel armor on all my wheels. truly a blessing for car guys. take time to do it, and you'll thank me later.
not only does it make washing much easier, it also prevents brake dust from not sticking as much as non-coated wheels hence easier washing.
