1.5T Civic Type R FK8 exhaust on Civic Sport FK7
UnicornX
El Paso, TX
2017 Civic Sport 6MT, 2017 Toyota Tacoma TRD Off-Road, 1999 Honda Civic LX
Recently a Civic Type R “FK8” exhaust popped up locally and it caught my attention as I wondered how it would sound/fit on my wife’s 2017 Civic Sport 6 speed.
I researched and found a few that had done it but only has testimonials on how it sounded after installation.
I was able to pick it up for a fair price and figured I’d share the result and post some videos. Now you’ll probably have to have a set of headphones on to really catch the sound result. It does have a more deeper tone at lower rpms, and now has a more distinct “vacuum” sound that these cars are known for.
As for as installation, it was a direct bolt on. I did have to trim a small part of the rear trim valance to accommodate the “3” tips. But other than that it was was straight forward. For what I picked it up for, I’m satisfied with the result in both the sound and appearance.
Honda Civic 10th gen Civic Type R FK8 exhaust on Civic Sport FK7 E3E4C812-7EBB-4DFF-ABE4-4202242D2B7D
Honda Civic 10th gen Civic Type R FK8 exhaust on Civic Sport FK7 C76A245E-9C2A-4F5E-AA29-E8069078C2F0
Hondanickx
Nick
Belgium
Thanks sounds perfect for me! Just a little bit more then stock.Is this a complete stock FK7 ?The only one i heard before was E-man's SI .
I have the Type-r exhaust as well and will modify it to fit on my base Sedan.
UnicornX
UnicornX
El Paso, TX
The only thing the car is equipped with is a prl intake tube and k&n.
_HatchED_
Eddie
South Carolina
2019 Hatchback Sport 6mt
Sounds good! Probably my favorite mod I've done to my hatchback, though I replaced the tips for something more subtle. I'm running mine along with a catless dp and fp and it's still pretty quiet!
MTBhatch
2018 Honda civic hatchback sport
If a fk8 stock exhaust fit on fk7, does that mean aftermarket fk8 exhaust fits fk7s?
LilToTo17
Kevin
Santa Rosa, CA
wheelwell.com
It could but would sound 100% nothing like an R lol so it’s not worth it
FK7Build
Minnesota
2018 Honda Civic Hatchback Sport Touring
Is there a difference in pipe diameter from the FK7 stock down pipe to where the FK8 exhaust connects? Also, does this require a tune?
Tonycivicboi
Tony
Civic Hatch Sport 6MT
Just wondering how do you guys trim the diffuser? DIY or shop? Worried its not going to look clean after cutting
_HatchED_
Eddie
South Carolina
I used a Dremel with a thin cutting wheel and just took my time with it. Afterwards I put a fresh blade in my utility knife and clean all the edges off.
Tonycivicboi
Tony
and it comes out smooth and shiny? Not jagged and cut?
LokFK7
Jeffrey
2017 Civic Sport
Do anyone know if the OEM Type R front pipe will fit onto the PRL downpipe for the FK7?
anestist
Anestis
Greece
I found a fk8 exhaust and I was thinking of installing it in my fk7 1.5 euro. I have read that a little bit of a trim has to been done to the rear diffuser of the pre f/l models. I drive a 2020 model which has a different diffuser. Does anybody know if trimming is required for that as well.
If there isn't that kind of information, can somebody, who has a fk8 exhaust, measure the width of the three tips from one side to another?
Mugenkb1
Southern California
05 Acura RL, 16 Acura MDX, 17 Civic Hatchback Sport 6MT
IIRC, the type R exhaust won't fit the 2020 bumper/ "diffuser" because the opening is too small.
Spencer2131
Spencer
Pittsburgh
2020 Honda Civic Hatchback Sport Touring
Correct you need a different diffuser. Abs dynamics sells a type r look alike. You can also bolt it up and try cutting. Aftermarket doesn't look at aerodynamics as well as Honda did.
