just rear? Dude just dremel the 2-3 mm you need off and base coat / prime over the cut. The fender arch is removable.running potenza s04 pole position...they are 10.7" wide from what tire rack said
Oh no. Just the front wheels from the NSX lol. They're 19in x 8.5injust rear? Dude just dremel the 2-3 mm you need off and base coat / prime over the cut. The fender arch is removable.
sorry I meant to address 02SilverSiHB and his tires rubbing the rear.Oh no. Just the front wheels from the NSX lol. They're 19in x 8.5in
An offset of +15? That's surely going to rub like crazy. I would avoid.Hey Guys,
Will the below specs fit the CTR?
SIZE: 8.5 X 18
OFFSET: 5/8
CENTER BORE: 72.6
BOLT PATTERN: 5 X 120
Ah shoot - was a good price for a winter set too lolAn offset of +15? That's surely going to rub like crazy. I would avoid.
I'm talking about the metal under the arch...I already did thatjust rear? Dude just dremel the 2-3 mm you need off and base coat / prime over the cut. The fender arch is removable.
SSR comp Type C 18x9 +55 offset.
Fits like a lego.
Your twins here....I have SSR typeC RS. my size r 18x8.5 et32,these wheels used to on my bmw.
Where'd you end up getting this wheel setup and for how much roughly?
Ah, man. Looks great. I just couldn't run +32
It used to mount on my bmw.i sold the car but keep the wheels.i can reuse now after 2yrs of storage.Where'd you end up getting this wheel setup and for how much roughly?
