Civic Si Lowering Springs Master Guide
  1. Mr.Apex
    Mr.Apex Member
    Jan 3, 2020
    Bay Area Ca.
    Dylan
    2020 Si Sedan
    #1 Mr.Apex, Feb 22, 2020
    I am new to this platform and forum and had run into troubles trying to find lowering spring info and options for the 10th gen SI (FC1/FC3) so i decided to create a master thread dedicated to the SI specifically like the one that exists here for the Type R (FK8).
    Another good reference thread is here where members have posted pictures of most setups.
    All info is from a representative at the company or the companies website itself.
    If you found this thread helpful please shoot me a thanks id really appreciate it.:thumbsup:
    SI OEM
    Front Spring Rate: 144.186 lbs/in
    Rear Spring Rate: 208.776 lbs/in
    (FK8) CTR OEM for reference
    Spring Rate Front: -263.2 lbs/in
    Spring Rate Rear: -235.2 lbs/in
    Eibcah PRO-KIT Performance Springs
    2017- 2020 Civic Si Sedan/coupe
    Part # E10-40-036-02-22
    Drop Front: .9"
    Drop Rear: 1.1"
    Spring Rates (Progressive)
    Front: 137-177 lb/in
    Rear: 83-256 lb/in
    $230
    Best price found here
    Eibach SPORT LINE
    TBD But in final stages to be realeased soon according to Kevin @ Eibach 2/20/20
    D2 Racing Lowering Springs
    2016-2020 Honda Civic/2017-2020 Civic Si
    Part# D2R D-SP-HN-25-3
    Front Drop (Coupe/Sedan): 1.7"
    Rear Drop (Coupe/Sedan): 1.9"
    Progressive Spring Rate
    Spring Rates "20% Stiffer than stock" need to verify
    $170
    Swift Spec R
    17+ Civic Sport/SI
    Part# 4H918R
    Front Drop: 1.1"
    Rear Drop: 1.1"
    Spring Rate (Dual)
    Front 229.5 lbs/in
    Rear 319.2 lbs/in
    $298
    Skunk 2
    '16-'18 Civic
    Part# 519-05-1775
    Front Drop: 1.375"
    Rear Drop: 1.25"
    Drop varies by chasis not specifically listed as SI compatible
    $173
    K Tuned
    16+ Civic (Coupe/Sedan/Hatchback) - DOES NOT FIT TYPE R
    Part# KTD-K1S-FC3
    Drop Front: 0.9"
    Drop Rear: 1"
    Spring Rate (Front): 173.6 lb/in
    Spring Rate (Rear): 252 lb/in
    $270
    Whiteline
    Listed as compatible with all 10th gen
    Part# WSK-HON017
    Drop Front: .8"
    Drop Rear: .8"
    Spring Rate (Progressive)
    Front 253 lb/in
    Rear 286 lb/in
    $233
    Tein S Tech
    FC1/FC3/FK7
    Part# SKHH6-AUB00
    Front Drop 1.2"
    Rear Drop 1.0"
    Spring Rate Front 146 lb/in
    Spring Rate Rear 174 lb/in
    $172
    RS*R
    2016+ Honda Civic Coupe / Sedan
    Part#: H057D
    Drop for Coupe:
    Front 1.0in to -1.2in
    Rear 1.4in to -1.6in
    Drop for Sedan:
    Rear 1.2in to -1.4in
    Spring Rates
    Front 148.40 lb/in
    Rear 188.71 lb/in
    $245
    H&R Sport Springs
    2016-2020 Honda Civic (Confirmed compatibility with SI)
    Part# H&R 51892
    Front Drop ~1.25"
    Rear Drop ~1"
    $233
    Fell free to post pictures of your setups just be sure to list what springs youre running.
    If any of this info is incorrect please let me know or if you have something to add and ill continue to update this post.
    Driver56, garf117, switterion and 24 others thanked this.
  2. SIckone
    SIckone Member
    Feb 15, 2020
    Nor Cal
    2019 Si Sedan
    Thank you for doing this. So appreciated.
    Mr.Apex thanked this.
  3. arpypat
    arpypat Senior Member
    Jun 29, 2019
    413
    405
    Occupation:
    Electrical Engineer
    Kansas City
    Arpan
    2019 Civic Si Sedan ABM
    Does anyone know if Type R springs fit the Si sedan?
    I wish someone would make stiffer springs for the Si, but w/o any drop. I think the stock height is perfect. The ktuned ones have a desirable spring rate, but the car is dropped too low for my taste.
    I'm thinking about the new Tein coils for the Si, but even on the highest setting, it's 0.8" lower than stock.
    Anyone have pics and/or reviews on the Whiteline ones?
    MutatedMango thanked this.
  4. Rafi27
    Rafi27 Member
    Feb 10, 2020
    Long Island, NY
    Rafeh
    2020 si
    HFP suspension is probably your best bet
  5. arpypat
    Jun 29, 2019
    413
    405
    Occupation:
    Electrical Engineer
    Kansas City
    Arpan
    Eh, I read that HFP suspension is softer than the stock Si when not in sport mode. Not worth $1600 IMO.
  6. Vegas Viking
    Vegas Viking Senior Member
    Aug 31, 2018
    145
    73
    The Boondocks, North Carolina
    2018 Civic Si Sedan
    Maybe it's my imagination, but the back looks higher than the front to me. I'm fine with the front height; wish there was a way to lower just the back.
  7. arpypat
    Jun 29, 2019
    413
    405
    Occupation:
    Electrical Engineer
    Kansas City
    Arpan
    The lines of the car make it seem like the front is lower.
    If you park on a level surface and measure from the center of your wheels to the fenders, you'll find that the front and rear measurements are near identical. Mine was about 14.5" on all 4 corners.
    Vegas Viking thanked this.
  8. Vegas Viking
    Aug 31, 2018
    145
    73
    2018 Civic Si Sedan
    Do I understand correctly that the Eibach Pro-Kit yields a mild or conservative drop?
  9. MutatedMango
    MutatedMango Senior Member
    Mar 24, 2019
    383
    153
    Philadelphia
    '19 Civic Si FC3
    Dude thank you so much for this super helpful. Been looking for a thread like this for a couple weeks and this answers everything. Hope it's stickied or something.
  10. MutatedMango
    Mar 24, 2019
    383
    153
    Philadelphia
    '19 Civic Si FC3
    Noticed this as well. Back is definitely higher looking
  11. joshhjackson2112
    joshhjackson2112 Senior Member
    Jul 3, 2018
    689
    411
    Raleigh, North Carolina
    Josh
    18' SI
    Yeah it is not a big drop. Good choice for people that want to limit rub from little to none with aggressive wheel/tire specs with the added benefit of lowering. Considered it myself many times but have changed my interests to Tein Coils
  12. Vegas Viking
    Aug 31, 2018
    145
    73
    2018 Civic Si Sedan
    IF I were to ever lower, I'd probably go with these Eibachs. Wouldn't want anything too drastic. Coilovers won't work with our dampers, correct?
  13. pinhead66
    pinhead66 Senior Member
    Jun 6, 2019
    103
    48
    Bay Area, CA
    2019 Civic Si Sedan, 2018 Odyssey EX-L
    Ground control does make a coilover kit that fits and works on the stock Si electronic dampers. It claims to have a range of stock height down to 1.75" lower. You can even pick your own spring rates. From reading various reviews though it seems to be more for tracking the car as it makes quite a bit of noise and racket.
  14. arpypat
    Jun 29, 2019
    413
    405
    Occupation:
    Electrical Engineer
    Kansas City
    Arpan
    Any coilover kit will work. But once you disconnect the factory dampers, you'll get a light on your dash saying there's an issue with the Adaptive Damper System.
    Some companies sell modules to plug into the factory damper connector that will simulate the electronic load of the factory damper and make sure you don't get any dash lights. People are calling these modules "ADS cancellers".
    AFAIK, Tein is the only company that gives you the ADS canceller modules included with their Flex Z coilover kit.
  15. Jaxson
    Jaxson Member
    Jan 25, 2020
    Philadelphia, PA
    2020 Civic Si Sedan
    But whyyyy get rid of the ADS? haha <= rhetorical question. I reallly like the stock setup and would not get rid of it but I can see why someone might not care for it and go to a manual adjustable setup.
