Cell Phone Holder Mount
8409_CW
Kabir
Atlanta, GA, USA
2018 CTR, 1992 Civic HB
It comes in two pieces. The magnet slides into a slot behind the hazard mount.
Got my mount the other day and its super sturdy. Went over a dozen speed bumps with no movement whatsoever.
Link to mount: https://amzn.to/2XPZ6cm
Thanks! I actually got mine earlier than expected and clipped it in. :)
Last night was my first really driving with it as well and I really liked it.
jtamase
the.xth
2019 Civic LX Hatchback; 2016 Pilot LX
does it come with a metal plate to put inside the case?
GoodBytes
Montreal
Honda Civic 2016 EX
I did not break my head. I got a windshield cellphone holder where the suction cup is sticky, and instead of putting it on my windshield, I put it on the place where you store your phone. Nice, clean and inconspicuous.
Jonathan89
Jonathan
La
Honda Civic si coupe 2017
Hi there! I'm in the process of making a phone holder that once I get it perfected I plan on sharing with others. Here's what I have so far.
I made a SLOPPY clay representation of what I wanted. Like others have said there's not a ton of great places that the phone wouldn't get in the way. In the position I'm thinking, it might brush my leg, but I can always fine turn new prototypes as I have full access to a 3D printer at work.
With this though comes the problem of the complex shape of that edge piece it will be binding to. I want to make it a good tight fit and I wasn't confident with calipers and trying to get some good dimensions off the plastic, so, I read up about making a 3D scanner and found I could make one with my XBOX 360 Kinect so I figured what the heck, I'll give it a shot. Here's a picture of my results:
This is going to give me a VERY solid rendering to start with at the very least. After I've completed the trails and errors, I'll be posting up end results (expect a finished product in 3 weeks as I'm going on vacation)
i seen the other post
Can you get me one of these for my Civic I like your idea better then the cleck
samuray
2008 Cbr600rr, 2016 civic LX, 2019 Civic Si
Honda Civic 10th gen Cell Phone Holder Mount 20190408_215656
Perfect place. the wire reaches to have Android auto as well
oriali
Ontario
2019 Civic Type R CW
Could you post another pic (or two) from a wider angle, with the phone mounted?
Also, is that this mount? https://www.amazon.ca/GETIHU-Universal-Dashboard-BlackBerry-Smartphone/dp/B075WSS482
Because I have a similar one from PrimeCables and I just spent a while tonight trying to figure out where to put it... your picture was something I thought about, but was worried the the faux carbon fibre surface wouldn't hold the mount well.
The only other location I can think of placing that magnet mount is on the right border, on the piano black finish of the infotainment.
Andjoo
Vancouver, BC
2018 Civic Type R - CW #19431
This is what I use for my phone mount.
Picked it up in Japan. I like it because it somewhat matches the CTR interior trim.
oriali
Ontario
Good to know it sticks well on the faux carbon trim, I was scared to put my magnet mount there (similar style to yours, small ball joint that's 360 rotatable).
Do you feel your phone is angled enough to look at when you drive? I'm contemplating placing mine to the left of the infotainment on the trim, above the starter.
Andjoo
Vancouver, BC
Placement of my phone is perfect where it is (viewing angle, reach etc). I don't ever really have to look at my phone, since I'm always using carplay.
Jonathan89
Jonathan
La
Where can I this mount
samuray
Thats the one I got, its taller than most magnetic mounts so its perfect to the carbon fiber area closer to driver seat and slightly overlaps the headunit when you put your phone. I followed instructions. didn't use it for 72 hrs and its perfect. I cant take a pic because I dont have another camera but my phone.
TidbitsSi
Reggie
Hawaii USA
2018 Civic Si Sedan
Puma
Brandon
Western Mass
2019 Civic Type R
Where did you order that screen protector?? I ordered one off amazon and the fitment is TERRIBLE! Thanks in advance
Yeet-n-Duner
j0
Tx
hb ex
I made it myself. It's very easy, you just buy a guitar capo and stick whatever mount you want to it. Mine is probably a bit more complicated because I had some preferences, like using my old mount, and wanting it to swivel 360 degree. I did not want to block vents, middle console pocket, or any buttons. I also did not want to reach for the phone, and did not want to obscure my view. I did not want to use adhesives or screws. I wanted it to look good when the phone was not in it. The design changed as I was making it too, which added some unnecessary complications. But essentially it's just a guitar capo with a go pro ball that fits into the original mount. Took some additional photos. I added the carbon fiber vinyl on to it. There is ample leg room, as some people were disputing that I'd knock it with my leg.
What it can do:
Tilt up/down/left/right
Swivel 360 degree at the base
Rotate 360 degree at the part that holds the phone
Adjust height up/down
Holds phone/tablet 4-8 inches
Can insert and remove with one hand
Reachable from steering wheel and from armrest without extending
Has a hole in the bottom to let you plug in
Easily tighten/loosen by the blue screw. I changed the screw color to match the color of my car
20171022_175940.jpg 20171022_180006.jpg 20171022_180041.jpg 20171022_180052.jpg 20171022_180108.jpg
i like your idea best!... which version guitar capo did you buy?
can you send me a link? also, is there a smaller version of that style?
thanks!
