CEL Code P0369
  1. Mature Banana
    Mature Banana Senior Member
    Sep 16, 2018
    141
    68
    Virginia
    CTR
    Started my 2019 FK8 yesterday after it sat for a week and I suddenly received emissions system and rev match system problem messages.
    My OBDII reader spat out error code P0369.
    P0369, according to the web tubes, is a cam shaft position sensor trouble code.
    I know there was an issue with wiring on 2017s that spat out the same messages but gave different CEL codes.
    Anyone seen this on 2018 or 2019 models and what was the fix?
    Just trying to gather as much info as I can before chatting with the stealership tomorrow. Cheers!
  2. SamuraiFK8
    SamuraiFK8 Member
    Aug 15, 2018
    Mission Viejo
    KG
    2018 FK8, Type R, 2004 Mercedes E500
    My 18 has done this twice now. Both times I was able to clear the codes by turning off auto rev matching/ then turning the car off. I then restarted the car, turned rev match back on and shut it off again. After a few minutes I restarted the car and the codes were cleared.
  3. OP
    Mature Banana
    Sep 16, 2018
    141
    68
    Virginia
    CTR
    #3 Mature Banana, Aug 7, 2019
    Thank you. I appreciate the info. I see that the error code is associated with a camshaft position sensor, and is supposedly an intermittent problem. I'm concerned at some point that something catastrophic could happen. The local dealer just kinda brushed me aside, saying not to worry about it.
  4. EnjoyDriving
    EnjoyDriving Senior Member
    Sep 3, 2018
    541
    133
    Minnesota
    2018 CW FK8
    so what does that mean? cam shaft problem? that would be a big problem wouldn't it?
  5. OP
    Mature Banana
    Sep 16, 2018
    141
    68
    Virginia
    CTR
    I'm just an idiot who doesn't know much but it doesn't sound good.
  6. FaDz
    FaDz Member
    May 13, 2018
    37
    Los angeles
    1987 200sx sev6; 2018 civic type-r
    This just happened to me today. The car started weird and threw that code. It cleared after i disconnected my flashpro and reconnected
  7. 02SilverSiHB
    02SilverSiHB Senior Member
    Jan 3, 2018
    2,246
    1,373
    Annapolis, MD
    2017 FK8
  8. OP
    Mature Banana
    Sep 16, 2018
    141
    68
    Virginia
    CTR
    Hope the car is okay. Did this issue get resolved?
  9. FaDz
    FaDz Member
    May 13, 2018
    37
    Los angeles
    i cleared the code and hasnt happened since. My friend said it prob was a bad start since i havent used it for a few days and im running a smaller odyssey battery aswell
  10. OP
    Mature Banana
    Sep 16, 2018
    141
    68
    Virginia
    CTR
    I see. Sounds like similar circumstances to me when I got that code. Glad everything is okay since.
  11. FaDz
    FaDz Member
    May 13, 2018
    37
    Los angeles
    did it pop up again for you?
  12. OP
    Mature Banana
    Sep 16, 2018
    141
    68
    Virginia
    CTR
    No. Like you, it seemed like the car had trouble to start after it had sat for a few days. No CEL since then (almost 6 months ago).
