Tried to start the car like normal and it just turns in the dash and doesn't crank.
Anybody else having this problem?
Yep..Tried to start the car like normal and it just turns in the dash and doesn't crank.
CTR or the 09 Si?Yep..
is it making a bell sound noise? mine did and it ended up being the ring gear coming off of the flywheel... being replaced under warranty.
have you tried unplugging battery for a few minutes than reconnect?
Already took it do the dealership, after it making a horrific metallic noise when starting, the ring gear on the flywheel broke free and wouldn't allow the car to start.have you tried unplugging battery for a few minutes than reconnect?
this will hard re-boot you CTRs ECU...could just be a glitch, like modern computers.
ok, thanks for the update.Already took it do the dealership, after it making a horrific metallic noise when starting, the ring gear on the flywheel broke free and wouldn't allow the car to start.
sounds like a manufacturing defect but no clue
What code was it when the diagnostics was hooked up?Already took it do the dealership, after it making a horrific metallic noise when starting, the ring gear on the flywheel broke free and wouldn't allow the car to start.
The engine over speed code is P0219What code was it when the diagnostics was hooked up?
