Car throwing codes and won’t start after Gentex Mirror
  1. nickjohn35
    nickjohn35 Senior Member
    Jul 9, 2018
    273
    207
    Occupation:
    Firefighter/Paramedic
    Cincinnati
    Nick
    Current: 2017 PMM Typer R. Former: 2004 350Z
    I’m in need of some serious help. I purchased a Gentex 453 autodim without compass/temp. I connected the 4 wire pigtail to the Automatic Dimming Mirror Attachment
    Honda Part No.: 08V03-TBA-100 (I’ll post a picture with how I connected the wires together). I plugged everything in and the mirror has no power and no autodim. Only thing that lights up are the Homelink buttons. To make matters even worse now my car won’t start. Won’t even turn over. I’ve disconnected the battery and let it sit for a while and tried again to only fail again. I checked the codes and it’s giving me a “P0102 Mass or Air Flow Sensor A Circuit Low” and “P0560 system voltage”.
  2. HSFBunny
    HSFBunny Member
    Dec 16, 2017
    42
    36
    Phoenix, Az
    2017 Honda Civic Si Coupe
    Dead battery. These cars are very sensitive to low voltage.
  3. voiddweller
    voiddweller Senior Member
    Aug 22, 2017
    94
    Occupation:
    Project Manager
    Ridgeland, MS
    '17 CTR, '04 TSX 6MT, '12 MDX, '97 240SX SR20DET
    Definitely rule out a dead or really low battery. It has all the symptoms.
  4. OP
    nickjohn35
    Jul 9, 2018
    273
    207
    Occupation:
    Cincinnati
    Nick
    It ended up being a blown fuse under the dash. Fuse 21 labeled as “ACG”.
    HSFBunny thanked this.
  5. OP
    nickjohn35
    Jul 9, 2018
    273
    207
    Occupation:
    Cincinnati
    Nick
    #5 nickjohn35, Apr 30, 2019
    Yes, battery was absolutely disconnected. I should’ve mentioned what blew the fuse. When I soldered the wires from Gentex pigtail to the Honda wire harness I didn’t individually insulate each solder joint before heat shrinking them. This caused a power surge and blew the fuse. Dumb me was doing this on little to no sleep the night before thanks to work and I totally overlooked it! But, I went back and did things properly and what would you know, it works perfectly now!
    voiddweller and EnjoyDriving thanked this.
  6. voiddweller
    Aug 22, 2017
    94
    Occupation:
    Project Manager
    Ridgeland, MS
    Thank you for following up!
    I have a Gentex that I'm going to install next week if I keep the car.
  7. OP
    nickjohn35
    Jul 9, 2018
    273
    207
    Occupation:
    Cincinnati
    Nick
    PM me if you need any help or have any questions!
  8. voiddweller
    Aug 22, 2017
    94
    Occupation:
    Project Manager
    Ridgeland, MS
    Will do!
